Navigate to the Arm examples directory in the ExecuTorch repository:
cd $HOME/executorch/examples/arm
Create a file named rps_tiny.py and paste the following code:
#!/usr/bin/env python3
Tiny Rock–Paper–Scissors CNN (PyTorch) + ExecuTorch export + CLI mini-game.
Usage:
# Train (fast) + export .pte + play
python rps_tiny.py --epochs 8 --export --play
# Just train (no export)
# Export previously trained weights to .pte
python rps_tiny.py --export
# Play the mini-game (uses the best weights on disk)
python rps_tiny.py --play
Outputs:
- rps_best.pt (best PyTorch weights)
- rps_labels.json (label map)
- rps_tiny.pte (ExecuTorch program, if --export)
import argparse, json, math, os, random, sys
from dataclasses import dataclass
from typing import Tuple, List
import numpy as np
from PIL import Image,ImageOps,ImageDraw, ImageFont, ImageFilter
import torch
import torch.nn as nn
import torch.optim as optim
from torch.utils.data import Dataset, DataLoader
# Config
SEED = 7
random.seed(SEED); np.random.seed(SEED); torch.manual_seed(SEED)
LABELS = ["rock", "paper", "scissors"] # indexes: 0,1,2
IMG_SIZE = 28
TRAIN_SAMPLES_PER_CLASS = 1000
VAL_SAMPLES_PER_CLASS = 200
BATCH = 64
LR = 2e-3
EPOCHS_DEFAULT = 6
WEIGHTS = "rps_best.pt"
LABELS_JSON = "rps_labels.json"
PTE_OUT = "rps_tiny.pte"
# Synthetic R/P/S renderer
def _rand(a, b):
return a + random.random()*(b-a)
def render_rps(label: str) -> Image.Image:
Render a 28x28 grayscale image for 'rock'/'paper'/'scissors'
using the letters R/P/S with random transforms + noise.
ch = {"rock":"R","paper":"P","scissors":"S"}[label]
img = Image.new("L", (IMG_SIZE, IMG_SIZE), color=0)
d = ImageDraw.Draw(img)
# Try to get a default truetype; fallback to PIL default bitmap font
font = None
try:
# Use a generic font size that fills the canvas
font = ImageFont.truetype(font="Arial.ttf", size=int(_rand(18,24)))
except Exception:
font = ImageFont.load_default()
# Random text position
bbox = d.textbbox((0, 0), ch, font=font) # (left, top, right, bottom)
w = bbox[2] - bbox[0]
h = bbox[3] - bbox[1]
x = (IMG_SIZE - w)//2 + int(_rand(-2, 2))
y = (IMG_SIZE - h)//2 + int(_rand(-2, 2))
# Random brightness for foreground
fg = int(_rand(180, 255))
d.text((x,y), ch, fill=fg, font=font)
# Slight blur/rotate/shear
if random.random()<0.6:
img = img.filter(ImageFilter.GaussianBlur(radius=_rand(0.0, 0.7)))
if random.random()<0.8:
angle = _rand(-18, 18)
img = img.rotate(angle, resample=Image.BILINEAR, expand=False, fillcolor=0)
# Add mild elastic-ish jitter by affine
if random.random()<0.5:
dx, dy = _rand(-1.0, 1.0), _rand(-1.0, 1.0)
ax = 1 + _rand(-0.05, 0.05)
img = img.transform(
img.size,
Image.AFFINE,
(ax, _rand(-0.05,0.05), dx, _rand(-0.05,0.05), 1+_rand(-0.05,0.05), dy),
fillcolor=0
# Salt & pepper noise
arr = np.array(img, dtype=np.float32)
noise = np.random.randn(*arr.shape)*_rand(3, 12)
arr = np.clip(arr + noise, 0, 255).astype(np.uint8)
img = Image.fromarray(arr, mode="L")
return img
# Dataset
@dataclass
class RPSItem:
image: torch.Tensor # [1,28,28] float32 0..1
label: int
class RPSDataset(Dataset):
def __init__(self, n_per_class: int, train: bool):
self.items: List[RPSItem] = []
for idx, name in enumerate(LABELS):
for _ in range(n_per_class):
img = render_rps(name)
# Slightly different augments for train vs val
if train and random.random()<0.15:
img = ImageOps.invert(img)
t = torch.from_numpy(np.array(img, dtype=np.float32)/255.0)[None, ...]
self.items.append(RPSItem(t, idx))
random.shuffle(self.items)
def __len__(self): return len(self.items)
def __getitem__(self, i):
it = self.items[i]
return it.image, torch.tensor(it.label, dtype=torch.long)
# Model: Tiny CNN (Ethos-friendly)
class TinyRPS(nn.Module):
Simple ConvNet:
[B,1,28,28] -> Conv3x3(16) -> ReLU -> Conv3x3(32) -> ReLU
-> MaxPool2d(2) -> Conv3x3(64) -> ReLU -> MaxPool2d(2)
-> flatten -> Linear(128) -> ReLU -> Linear(3)
def __init__(self):
super().__init__()
self.body = nn.Sequential(
nn.Conv2d(1, 16, 3, padding=1), nn.ReLU(inplace=True),
nn.Conv2d(16, 32, 3, padding=1), nn.ReLU(inplace=True),
nn.MaxPool2d(2),
nn.Conv2d(32, 64, 3, padding=1), nn.ReLU(inplace=True),
nn.MaxPool2d(2),
self.head = nn.Sequential(
nn.Flatten(),
nn.Linear(64*7*7, 128), nn.ReLU(inplace=True),
nn.Linear(128, 3)
def forward(self, x): # x: [B,1,28,28]
return self.head(self.body(x))
# AOT entry points expected by aot_arm_compiler
ModelUnderTest = TinyRPS()
ModelInputs = (torch.zeros(1, 1, IMG_SIZE, IMG_SIZE, dtype=torch.float32),)
# Train / Eval
def run_epoch(dl, model, crit, opt=None):
train = opt is not None
model.train() if train else model.eval()
totl=totc=cnt=0
with torch.set_grad_enabled(train):
for x,y in dl:
if train: opt.zero_grad(set_to_none=True)
out = model(x)
loss = crit(out, y)
if train:
loss.backward()
opt.step()
totl += float(loss)*x.size(0)
totc += (out.argmax(1)==y).sum().item()
cnt += x.size(0)
return totl/cnt, totc/cnt
# Export to ExecuTorch (.pte)
def export_to_pte(model: nn.Module, out_path=PTE_OUT):
model.eval()
example = torch.zeros(1,1,IMG_SIZE,IMG_SIZE, dtype=torch.float32)
exported = None
try:
try:
from torch.export import export
except Exception:
import torch._export as _export
export = _export.export
exported = export(model, (example,))
except Exception:
# Fallback: some older builds expose exir.capture
from executorch.exir import capture
exported = capture(model, (example,))
from executorch import exir
edge = exir.to_edge(exported)
prog = edge.to_executorch()
with open(out_path, "wb") as f:
f.write(prog.buffer)
print(f"[export] wrote {out_path}")
# CLI mini-game
def ascii_show(img: torch.Tensor) -> str:
"""Convert [1,28,28] tensor into tiny ASCII block for fun."""
chars = " .:-=+*#%@"
arr = (img.squeeze(0).numpy()*255).astype(np.uint8)
h, w = arr.shape
lines=[]
for y in range(0,h,2):
row=[]
for x in range(0,w,1):
v = arr[y, x]
row.append(chars[min(len(chars)-1, int(v)*len(chars)//256)])
lines.append("".join(row))
return "\n".join(lines)
def beats(a: int, b: int) -> int:
"""Return +1 if a beats b, 0 if tie, -1 if loses."""
# 0=rock beats 2=scissors, 1=paper beats 0, 2=scissors beats 1
if a == b: return 0
if (a==0 and b==2) or (a==1 and b==0) or (a==2 and b==1): return +1
return -1
def play_game(model: nn.Module):
print("\n=== Rock–Paper–Scissors: Play vs Tiny CNN ===")
print("Type one of: rock / paper / scissors / quit\n")
while True:
s = input("Your move> ").strip().lower()
if s in ("quit","q","exit"): break
if s not in LABELS:
print("Invalid. Try: rock / paper / scissors / quit")
continue
# Generate an image of YOUR move and one for OPPONENT
your_idx = LABELS.index(s)
your_img = render_rps(s)
opp_idx = random.randint(0,2)
opp_img = render_rps(LABELS[opp_idx])
# Classify both with the model on CPU
def to_tensor(im):
return torch.from_numpy(np.array(im, dtype=np.float32)/255.0)[None,None,...]
with torch.no_grad():
y_logits = model(to_tensor(your_img))
o_logits = model(to_tensor(opp_img))
y_pred = int(y_logits.argmax(1).item())
o_pred = int(o_logits.argmax(1).item())
y_conf = torch.softmax(y_logits,1)[0,y_pred].item()
o_conf = torch.softmax(o_logits,1)[0,o_pred].item()
print("\nYou played:", s)
print(ascii_show(to_tensor(your_img)[0]))
print(f"Model thinks you played: {LABELS[y_pred]} ({y_conf*100:.1f}%)")
print("\nOpponent played (hidden):")
print(ascii_show(to_tensor(opp_img)[0]))
print(f"Model thinks opponent played: {LABELS[o_pred]} ({o_conf*100:.1f}%)")
outcome = beats(y_pred, o_pred)
if outcome>0: print("\n🎉 You win!")
elif outcome<0: print("\n😅 You lose!")
else: print("\n🤝 It's a tie!")
print("-"*50)
# Main
def main():
ap = argparse.ArgumentParser()
ap.add_argument("--epochs", type=int, default=EPOCHS_DEFAULT)
ap.add_argument("--no-train", action="store_true", help="skip training (use saved weights)")
ap.add_argument("--export", action="store_true", help="export ExecuTorch .pte after training")
ap.add_argument("--play", action="store_true", help="play the mini-game after (or without) training")
args = ap.parse_args()
# Always save label map for runners
with open(LABELS_JSON, "w") as f:
json.dump({"labels": LABELS}, f, indent=2)
model = TinyRPS()
if not args.no_train:
print("== Building synthetic datasets ==")
tr = RPSDataset(TRAIN_SAMPLES_PER_CLASS, train=True)
va = RPSDataset(VAL_SAMPLES_PER_CLASS, train=False)
train_loader = DataLoader(tr, batch_size=BATCH, shuffle=True, num_workers=0)
val_loader = DataLoader(va, batch_size=BATCH, shuffle=False, num_workers=0)
print(f"Train size: {len(tr)} | Val size: {len(va)}")
crit = nn.CrossEntropyLoss()
opt = optim.Adam(model.parameters(), lr=LR, weight_decay=1e-4)
best = -1.0
for e in range(1, args.epochs+1):
tl, ta = run_epoch(train_loader, model, crit, opt)
vl, vaa = run_epoch(val_loader, model, crit, None)
print(f"Epoch {e:02d}/{args.epochs} | train {ta*100:5.2f}% | val {vaa*100:5.2f}%")
if vaa > best:
best = vaa
torch.save(model.state_dict(), WEIGHTS)
print(f" ↑ saved {WEIGHTS} (val {vaa*100:.2f}%)")
print("Training done.")
else:
print("--no-train: skipping training")
# Load best weights if present
if os.path.exists(WEIGHTS):
model.load_state_dict(torch.load(WEIGHTS, map_location="cpu"))
model.eval()
print(f"Loaded weights from {WEIGHTS}")
else:
print(f"[warn] No weights file {WEIGHTS}; using random init.")
if args.export:
try:
export_to_pte(model, PTE_OUT)
except Exception as e:
print("[export] failed:", e)
if args.play:
play_game(model)
if __name__ == "__main__":
main()
The script handles the entire workflow: data generation, model training, and a simple command-line game.
render_rps() that generates 28x28 grayscale images of the letters ‘R’, ‘P’, and ‘S’ with random rotations, blurs, and noise. This creates a diverse dataset that’s used to train the model.rps_best.pt.export_to_pte() function. This function uses the torch.export module (or a fallback) to trace the trained PyTorch model and convert it into an ExecuTorch program (.pte). This compiled program is highly optimized for deployment on any target hardware, for example Cortex-M or Cortex-A CPUs for embedded devices.Train the model, export it, and play the game:
You’ll see training progress similar to:
Train size: 3000 | Val size: 600
Epoch 01/8 | train 80.03% | val 98.67%
↑ saved rps_best.pt (val 98.67%)
Epoch 02/8 | train 99.57% | val 100.00%
↑ saved rps_best.pt (val 100.00%)
Epoch 03/8 | train 99.83% | val 99.83%
Epoch 08/8 | train 100.00% | val 100.00%
Training done.
Loaded weights from rps_best.pt
[export] wrote rps_tiny.pte
After training and export, the game starts. Type rock, paper, or scissors, and review the model’s predictions for you and a random opponent:
Your move> rock
You played: rock
Model thinks you played: rock (100.0%)
Model thinks opponent played: paper (100.0%)
😅 You lose!
Your move> paper
You played: paper
Model thinks you played: paper (100.0%)
Model thinks opponent played: rock (100.0%)
🎉 You win!
Your move>
Type quit to exit the game. In the next chapter, you’ll prepare the model to run on the FVP.
