# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/training-inference-pytorch/)
- [Set up your environment](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/training-inference-pytorch/env-setup-1/)
- [Train and Test the rock-paper-scissors Model](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/training-inference-pytorch/fine-tune-2/)
- [Run the model on Corstone-320 FVP](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/training-inference-pytorch/fvp-3/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/training-inference-pytorch/_next-steps/)
## Explore related resources
- [Run Llama 3 on a Raspberry Pi 5 using ExecuTorch](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/rpi-llama3)
- [ExecuTorch examples](https://github.com/pytorch/executorch/blob/main/examples/README.md)
## Review frequently asked questions
### Where should I put the rock–paper–scissors script before training?
Place the script in the ExecuTorch repository under the Arm examples directory at `\$HOME/executorch/examples/arm`.
### How do I launch the mini‑game after training?
Run the script with the play option. The mini‑game uses the best weights found on disk.
### How do I know the export to ExecuTorch worked?
A successful export produces a `.pte` file. Check that the file is created in the expected location after running the export step.
### Do I need a dataset or camera for training?
You don’t need an external dataset or camera because you’ll use synthetic data generation for training. The model learns to classify images of the letters R, P, and S.
### Which log messages confirm that the model starts on the Corstone-320 FVP?
Check the FVP output for the model loading and `Running method forward` messages. An `EthosUBackend.cpp` initialization message confirms that the Ethos-U backend starts during inference.
