Profile Linux kernel modules with Arm Streamline
Set up your environment
Build the out-of-tree kernel module
Profile the out-of-tree kernel module
Integrate a custom character device driver into the Linux kernel
Profile the in-tree kernel driver
Use Streamline with the Statistical Profiling Extension
In the previous steps, you built and profiled an out-of-tree kernel module. Now, you’ll learn how to integrate a driver directly into the Linux kernel source tree. By statically linking your driver, you can profile it using Streamline by adding the kernel’s vmlinux file in the capture settings. This approach lets you analyze function calls, call paths, and specific kernel code sections that might affect performance, just as you did with the out-of-tree module.
Use the same example character driver you used earlier mychardrv. This time, you will be statically linking it to the kernel.
Go to your kernel source directory, which in this case is located in Buildroot’s output directory in $(BUILDROOT_HOME)/output/build/linux-custom.
Copy the mychardrv.c file created earlier to drivers/char directory:
cd drivers/char
cp <mychardrv.c file> ./mychardrv.c
Add the following configuration to the bottom of the Kconfig file to make the kernel configuration system aware of the the new driver you just added:
config MYCHAR_DRIVER
tristate "My Character Driver"
default y
help
A simple character device driver for testing.
endmenu
You also need to modify the Makefile in the current directory to make it build the object file for mychardrv.c. Add the following line to it:
obj-$(CONFIG_MYCHAR_DRIVER) += mychardrv.o
You can rebuild the Linux image simply by running the make command in your Buildroot directory. This rebuilds the Linux kernel including the new device driver and produces a debuggable vmlinux ELF file:
cd $(BUILDROOT_HOME)
make -j$(nproc)
To verify that the driver was compiled into the kernel, run the following command:
find $(BUILDROOT_HOME) -iname "mychardrv.o"
The output gives you the full path to the object file for your character device driver. This confirms that the kernel build process included your driver.
Next, flash the updated sdcard.img file to your target’s SD card. This step can be confusing at first, but it’s essential for running your new kernel with the integrated driver on your Arm device.
To learn how to flash the sdcard.img file to your SD card, see this helpful article .
When you integrate your driver into the kernel source tree, it loads automatically each time Linux boots. You don’t need to manually insert the module as your character device driver is ready to use as soon as the system starts.
