Inspect the streaming decisions
The application sends one PROB line over the simulated UART for every 512-sample frame. It also merges consecutive speech frames into SEGMENT lines.
Inspect the first probability records and the detected speech segments:
grep -Eo 'PROB .*$' \
  fvp.log | head -n 10
grep -Eo 'SEGMENT .*$' \
  fvp.log
The output is similar to:
        PROB 0.000 0.062716 silence
PROB 0.032 0.105834 silence
PROB 0.096 0.936824 speech
SEGMENT 0.096 0.224 speech
SEGMENT 0.288 1.952 speech
Each PROB line contains the frame timestamp in seconds, the probability of speech, and the decision produced with a threshold of 0.5. Your probability values and speech segments depend on the validation audio.
The validation question is: Did the host and FVP label every frame the same way? In the reference run, both the host and FVP found speech from 0.096 to 0.224 seconds and from 0.288 to 1.952 seconds, with no decision mismatches.
Image Alt Text:Two matching timelines for the same 2.5-second audio clip. The host reference and FVP output show speech from 0.096 to 0.224 seconds and from 0.288 to 1.952 seconds. All 79 frame decisions match.Host and FVP produce the same speech decisions
Compare the host and FVP results
Compare the saved host reference with the probabilities in the FVP serial log:
source .venv/bin/activate
python examples/arm/silero_vad_example_ethos_u/runtime/compare_vad_probs.py \
  --expected expected_probs.bin \
  --actual-log fvp.log \
  --atol 0.25 \
  --mean-atol 0.02
The comparison must report 79 probability values and zero threshold mismatches at 0.500. The expected final output is:
        Validation passed
It checks that both outputs contain the same number of finite probabilities, that maximum and mean absolute errors stay within 0.25 and 0.02, and that every frame has the same speech or silence decision.
The exporter restores the recurrent state after generating the reference, so the host and FVP start from the same state. This checks deployment consistency against the quantized host model. Measuring speech-detection accuracy requires labelled audio.
What you’ve accomplished
You’ve completed an end-to-end streaming audio workflow for Arm Ethos-U. You exported Silero VAD with model-owned recurrent state and built a bare-metal Cortex-M85 application. You ran the application on the Corstone-320 FVP, and validated its speech decisions against a host reference.
You can now replace the example audio with another 16 kHz mono, 16-bit PCM WAV file, or use the runtime integration as a starting point for an Ethos-U85 device.
