Deploy Silero VAD on Arm Ethos-U with ExecuTorch
Build ExecuTorch for Cortex-M85
You already have the exported model and validation audio. You’ll package both the model and audio into a bare-metal application and run the application on a virtual Cortex-M85 and Ethos-U85 system.
Start by building ExecuTorch for Cortex-M85.
Continue from the ExecuTorch repository root. Activate the environment and build the target libraries:
source .venv/bin/activate
source examples/arm/arm-scratch/setup_path.sh
if [ "$(uname -s)" = Darwin ]; then
export PATH="$PWD/examples/arm/arm-scratch/FVPs-on-Mac/bin:$PATH"
export FVP_MOUNT_DIR="$PWD"
fi
cmake --preset arm-baremetal \
-DCMAKE_BUILD_TYPE=Release \
-DTARGET_CPU=cortex-m85 \
-B cmake-out-arm -S .
cmake --build cmake-out-arm --target install --parallel 2
The installed libraries provide the ExecuTorch runtime, portable operators, and Ethos-U backend used by the application.
Build the Silero VAD application
Configure the application with the exported model, validation audio, and the default speech threshold of 0.5. The command selects the UART address required by FVPs-on-Mac:
runtime_cmake_args=()
runtime_cmake_args+=(-DUART0_BASE=0x49303000)
fi
cmake \
"${runtime_cmake_args[@]}" \
-DCMAKE_TOOLCHAIN_FILE="$PWD/examples/arm/ethos-u-setup/arm-none-eabi-gcc.cmake" \
-DET_PTE_FILE_PATH="$PWD/silero_vad_ethos_u.pte" \
-DAUDIO_PATH="$PWD/silero-vad/validation.wav" \
-B examples/arm/silero_vad_ethos_u \
-S examples/arm/silero_vad_example_ethos_u/runtime
Build the configured application:
cmake --build examples/arm/silero_vad_ethos_u \
--target silero_vad_ethos_u --parallel 2
The build creates examples/arm/silero_vad_ethos_u/silero_vad_ethos_u. This ELF image contains both the .pte model and the 2.5-second validation clip.
Run Silero VAD on the FVP
Run the application and save its simulated UART output to fvp.log:
set -o pipefail
bash backends/arm/scripts/run_fvp.sh \
--elf=examples/arm/silero_vad_ethos_u/silero_vad_ethos_u \
--target=ethos-u85-256 \
--timeout=300 2>&1 | tee fvp.log
The application processes one audio frame every 32 ms of recording time, then prints the probabilities and a summary. The output is similar to:
2 segments, 79 frames, 2.5s
Speech: 56/79 frames (70.9%)
Model executed successfully.
Simulation complete, 0
No problems found!
Check the target artifacts
Confirm that the application and its serial log exist:
for artifact in \
fvp.log; do
test -s "$artifact" || {
echo "Missing target artifact: $artifact" >&2
exit 1
done
echo "Target artifacts verified."
You’ve run the stateful Silero VAD model on a virtual Cortex-M85 and Ethos-U85 target.
Next, you’ll inspect the speech decisions and compare them with the host reference.
