# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/rpi_pico/)
- [How do I install the Raspberry Pi Pico SDK?](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/rpi_pico/sdk/)
- [How do I run Hello World for Raspberry Pi Pico?](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/rpi_pico/hello/)
- [How do I measure RPi Pico Application Performance?](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/rpi_pico/perf/)
- [How do I debug RPi Pico applications?](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/rpi_pico/debug/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/rpi_pico/_next-steps/)
- Continue Learning
### Read related resources
- [Raspberry Pi Pico SDK documentation](https://raspberrypi.github.io/pico-sdk-doxygen/)
- [Raspberry Pi Pico documentation](https://www.raspberrypi.com/documentation/microcontrollers/raspberry-pi-pico.html)
### Give Feedback
- What is the primary reason for your feedback?
  - Missing information
  - Too complicated / unclear steps
  - Code problems
  - Out of date
  - Easy to understand
  - Solved my problem
  - Excellent code snippets
Thank you! We're grateful for your feedback.
- Have more feedback? [Log an issue on GitHub.](https://github.com/ArmDeveloperEcosystem/arm-learning-paths/issues/new?title=Feedback%20-%20Get%20started%20with%20Raspberry%20Pi%20Pico)
- Want to collaborate? [Join our Discord server.](https://discord.com/invite/armsoftwaredev)
[Back to all learning paths under Embedded and Microcontrollers](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/)
