Give feedback
AI-assisted
Close
What result should I expect when I run the GPIO test script?
The LED connected to GPIO 17 should turn on and off as coded without GPIO-related errors. If nothing changes, check the wiring and pin selection in the script.
Which GPIO pin and resistor value does the LED example use?
Use GPIO 17 (physical pin 11) with a 220Ω series resistor. Connect the LED anode (long leg) to GPIO 17 through the resistor and the cathode (short leg) to a GND pin.
How do I access the assistant’s web interface and know it started correctly?
The script starts a local web server and prints the address and port in the terminal. Open a browser to your Raspberry Pi’s IP at that port. A responsive page indicates the server is running.
Where should I run the assistant code after cloning it, and what should I see?
Change into the cloned project directory before launching smart_home_assistant.py. On start, it initializes the configured GPIO devices and brings up the local web server.
What should I check if natural language commands don't control the LED or other device?
Verify the wiring to GPIO 17 and GND, and ensure the script’s pin assignments match your setup. Confirm Ollama is installed and available so the assistant can process model replies, and review the console for JSON parsing or connection errors.
Return to Embedded and Microcontrollers
