The next step is to test the GPIO functionality. In this section, you configure an LED light to simulate a smart home device.
Gather your electronic components. Connect the anode (long leg) of an LED in series with a 220Ω resistor to GPIO 17 (physical pin 11). Connect the cathode (short leg) to a ground (GND) pin.
See the image below for the full setup:
Raspberry Pi connected to a breadboard with a green LED and jumper wires
Create a Python script named testgpio.py:
cd $HOME/smart-home
vim testgpio.py
Add the following code to the file:
#!/usr/bin/env python3
import time
from gpiozero import Device, LED
from gpiozero.pins.lgpio import LGPIOFactory
# Set lgpio backend for Raspberry Pi 5
Device.pin_factory = LGPIOFactory()
# Set up GPIO pin 17
pin1 = LED(17)
try:
while True:
pin1.toggle() # Switch pin 17 state
time.sleep(2) # Wait 2 seconds
except KeyboardInterrupt: # Ctrl+C pressed
pin1.close() # Clean up pin 17
Run the script:
python testgpio.py
The LED should blink every two seconds. If you observe this behavior, your GPIO setup works correctly.
If you run into issues with the hardware setup, check the following:
sudo apt-get install -f
sudo or add your user to the gpio group. Don’t forget to log out for the changes to take effect:
sudo usermod -a -G gpio $USER
raspi-config if neededWith GPIO pins working, you can now move on to the next section to interact with devices using language models and the user interface.
