Migrating Projects to CMSIS v6
Check your versions against the supported list: Arm Compiler for Embedded v6 and later, Arm GNU Toolchain v12 and later, LLVM v16 and later, or IAR Embedded Workbench for Arm v9.30 and later. Use the
Arm Compiler for Embedded Migration and Compatibility Guide
to move from v5 to v6.
Install
ARM.CMSIS.6.0.0.pack, ARM.Cortex_DFP.1.0.0.pack, and ARM.CMSIS-RTX.5.8.0.pack. These packs replace the ARM.CMSIS.5.x.x pack during migration to CMSIS v6.Install
ARM.CMSIS-View.1.1.0.pack and ARM.CMSIS_Compiler.2.0. These packs contain the content that moved from the deprecated Keil.ARM_Compiler pack.Change the device selection from the CMSIS v5 generic device to the corresponding device in the
Cortex_DFP pack. Use the included device mapping table to select the matching ARMCMx variant and features.For instructions, see the
Convert uvprojx-based projects to csolution
Learning Path. It covers importing, converting, and building
uvprojx projects in Keil Studio for VS Code and on the command line.
