# Set up the pqm4 development environment
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/pqc_pqm4/)
- [Understand pqm4 and post-quantum cryptography](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/pqc_pqm4/introduction/)
- [Set up the pqm4 development environment](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/pqc_pqm4/setup-installation/)
- [Run pqm4 tests and benchmarks](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/pqc_pqm4/running-tests-and-benchmarks/)
- [Add a KEM implementation to pqm4](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/pqc_pqm4/adding-new-schemes/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/pqc_pqm4/_next-steps/)
## Download and install dependencies for pqm4
In this section, you’ll install all dependencies needed to build and run pqm4.
You’ll need Python 3.8 or higher on your host machine. You’ll also need one of the following to run pqm4:
- A physical Arm Cortex-M4 development board such as NUCLEO-L4R5ZI (the pqm4 default), NUCLEO-L476RG, or STM32F4 Discovery, plus stlink or OpenOCD for flashing
- QEMU, if you want to simulate a Cortex-M4 environment using the `mps2-an386` platform without physical hardware
After downloading and installing dependencies, follow the steps to configure either a physical board or QEMU.
### Install the Arm GNU Toolchain
Follow the [Arm GNU Toolchain install guide](https://learn.arm.com/install-guides/gcc/arm-gnu/) to install `arm-none-eabi-gcc` on your host machine.
> **Note:** Use toolchain version 12.x. Other versions may work but have not been tested.
Verify the installation by running:
arm-none-eabi-gcc --version
The output is similar to:
arm-none-eabi-gcc (Arm GNU Toolchain 12.3.Rel1) 12.3.1 20230626
Copyright (C) 2022 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
### Download pqm4 and submodules
Clone the pqm4 repository including all submodules:
git clone --recursive https://github.com/mupq/pqm4.git
cd pqm4
### Install Python dependencies
Create a virtual environment inside the pqm4 directory and install the required modules:
python3 -m venv venv
source venv/bin/activate
pip install pyserial tqdm
Activate the virtual environment each time you open a new terminal before running pqm4 Python scripts:
## Configure a physical board
If you’re using a physical development board, follow these steps to configure it.
### Install stlink
Install stlink using your package manager.
On Linux:
sudo apt-get install stlink-tools
On macOS:
brew install stlink
If you need to build from source on Linux:
sudo apt-get install libusb-1.0-0-dev -y
git clone https://github.com/stlink-org/stlink.git
cd stlink
make release
Verify the connection to your board:
st-info --probe
Found 1 stlink programmers
### (Optional) Install OpenOCD
If you are using a physical board and stlink does not support it, install OpenOCD as an alternative.
On Linux:
sudo apt-get install openocd -y
On macOS:
brew install openocd
If your package manager provides an older version that doesn’t support your board, you can build from source instead:
sudo apt install libjim-dev libtool-bin -y
git clone https://github.com/openocd-org/openocd.git
cd openocd
./bootstrap
./configure
make
sudo make install
### (Optional) Install ChipWhisperer
ChipWhisperer is required only if you’re using the `cw308t-stm32f3` platform. If you’re using another board such as NUCLEO or STM32 Discovery, skip this section.
Install it using pip:
python3 -m pip install chipwhisperer
### Build for a target platform
Build pqm4 by specifying the platform identifier for your board using the `PLATFORM` variable.
For NUCLEO-L4R5ZI (the pqm4 default):
make -j4 PLATFORM=nucleo-l4r5zi
For NUCLEO-L476RG:
make -j4 PLATFORM=nucleo-l476rg
For STM32F4 Discovery:
make -j4 PLATFORM=stm32f4discovery
For a full list of supported platforms, see the [pqm4 README](https://github.com/mupq/pqm4).
### Configure the serial port
The script `host_unidirectional.py` uses a default serial port (often `/dev/ttyUSB0`) which might not match your system. Update it to match your board’s serial port.
On macOS:
ls /dev/tty.*
On Linux:
ls /dev/ttyACM* /dev/ttyUSB*
Open the script:
nano hostside/host_unidirectional.py
Update this line with your actual port:
```python
dev = serial.Serial("/dev/tty.usbmodemXXXX", 38400)
### Flash and verify communication
Connect the board to your host machine using the mini-USB port to provide power and enable flashing.
Flash a test binary:
st-flash write bin/boardtest.bin 0x8000000
Read the output from the board:
python3 hostside/host_unidirectional.py
Press the RESET button on the board. The output is similar to:
Hello world
Stack Size
Random number
If you see this output, your board is flashed, communicating over serial, and ready to run pqm4.
## Configure QEMU
If you’re using QEMU instead of a physical board, follow these steps:
### Install QEMU
Install QEMU to simulate a Cortex-M4 environment using the `mps2-an386` machine type.
On macOS:
brew install qemu
On Linux:
sudo apt-get install qemu-system-arm -y
Build pqm4 by specifying the platform identifier for QEMU simulation using the `PLATFORM` variable:
make -j4 PLATFORM=mps2-an386
Communication with QEMU is covered in the next section.
## What you’ve accomplished and what’s next
You’ve now installed the Arm GNU Toolchain, installed required Python dependencies, and cloned the pqm4 repository. You’ve also set up either a physical Arm Cortex-M4 development board or QEMU to build and run pqm4.
Next, you’ll run the pqm4 test suite and benchmarks to measure the performance of post-quantum algorithms.
