Explore related resources
Give feedback
AI-assisted
Close
Which target should I use: a physical Cortex-M4 board or QEMU?
Use a physical board if you have supported hardware and a flashing tool (stlink or OpenOCD). Choose QEMU to simulate a Cortex-M4 using the mps2-an386 platform when hardware isn’t available.
How do I know the pqm4 build completed successfully?
You’ll see binaries under bin/ for each scheme you built. The filenames follow a pattern such as bin/crypto_kem_ml-kem-768_<impl>_<type>.bin, indicating the scheme and implementation variant.
What do implementation variants such as `m4fspeed` and `m4fstack` indicate?
The <impl> field identifies each scheme’s variant. For example, m4fspeed is optimized for speed and is used by ML-KEM, while m4fstack is another Cortex-M4F variant. The exact suffix depends on the scheme.
What results should I expect when running tests and benchmarks?
The test harness validates correctness against known test vectors. Benchmarks report standardized metrics, including cycle counts, stack usage, and code size.
How do I add a new KEM and verify it's picked up by pqm4?
Place the new scheme in its own directory under crypto_kem/. pqm4’s build system automatically discovers and compiles it. Verify by checking for generated binaries for the new scheme and running the tests and benchmarks.
Return to Embedded and Microcontrollers
