Give feedback
AI-assisted
Close
How can I tell that the initial export uses only Cortex-M?
Check that the exported graph has no executorch_call_delegate node. You’ll see supported patterns lowered to cortex_m.* operators, while aten.topk remains portable. In this model, the quantized convolutions use CMSIS-NN, but other Cortex-M operators can use different implementations.
Which execution paths does the mixed model use?
Inspect the exported operator list. You’ll find the stride-1 convolution in an Ethos-U55 delegate and the stride-4 convolution on Cortex-M55 through CMSIS-NN. The remaining topk operation uses a portable ExecuTorch CPU kernel.
How do I trace exported operations to CMSIS Pack components?
Inspect cmsis-executorch-u55.cbuild-pack.yml for the resolved ExecuTorch and CMSIS-NN Pack versions, then inspect ai_layer/ai_layer.clayer.yml for the components selected from those Packs. You’ll find the Ethos-U backend, Cortex-M operator wrappers, CMSIS-NN library, and portable topk component.
How does the CMSIS project include the model and AI layer?
Inspect cmsis-executorch-u55.csolution.yml to see the SSE-300-U55 target and its Board and AI layer references. The generated AI layer selects the runtime components of the model. The project generates model_pte.c from model.pte, so the bare-metal application can load the program without a filesystem.
What does the final FVP run verify?
compile_commands.json confirms that the build compiled the expected ExecuTorch, Ethos-U, CMSIS-NN, and portable topk sources. On the FVP, Test_result: PASS tells you that inference returned a nonempty output list. Check that the output also reports ten values. You need a reference comparison to assess numerical accuracy.
Return to Embedded and Microcontrollers
