Build the application
Now that you’ve understood how the application works, build and run it.
In the Visual Studio Code (VS Code) CMSIS view, confirm that cmsis-executorch-u55.csolution.yml is the active solution. Confirm that SSE-300-U55 is the selected target.
Then, select Build to compile the application using the AI layer that you generated earlier.
CMSIS-Toolbox combines the App, Board, and AI layers, resolves their selected components, and invokes Arm Compiler for Embedded. Check that the build task finishes successfully without errors. Confirm that the build produces cmsis-executorch.axf and cmsis-executorch.hex under:
out/cmsis-executorch/SSE-300-U55/Debug/
The .axf file contains the linked executable and debug information. The .hex file contains the image loaded into the Fixed Virtual Platform (FVP).
Verify the compiled source paths
A successful build proves that an image was produced, but it doesn’t by itself show which implementation supplied each operation. In the VS Code terminal, ensure that .venv is activated and you’re in the project root directory.
Then, run the verification helper against the compilation database:
python verify_pack_sources.py \
  out/cmsis-executorch/SSE-300-U55/Debug/compile_commands.json
python .\verify_pack_sources.py `
  .\out\cmsis-executorch\SSE-300-U55\Debug\compile_commands.json
The expected output is:
        PASS: ExecuTorch runtime was compiled from its declared CMSIS Pack
PASS: ExecuTorch Cortex-M convolution wrapper was compiled from its declared CMSIS Pack
PASS: CMSIS-NN convolution kernel was compiled from its declared CMSIS Pack
PASS: Ethos-U backend was compiled from its declared CMSIS Pack
PASS: ExecuTorch portable topk kernel was compiled from its declared CMSIS Pack
These checks distinguish the two layers of the optimized fallback. The ExecuTorch Pack provides the quantized_conv2d wrapper. The CMSIS-NN Pack provides the convolution implementation that wrapper calls.
Together with cmsis-executorch-u55.cbuild-pack.yml, the compilation database shows that both the resolved Pack versions and the source files compiled.
Run the image on the FVP
In the same VS Code terminal, start the Corstone-300 model and load the generated HEX image. On macOS, use the Docker wrapper that you configured during setup:
FVP_Corstone_SSE-300_Ethos-U55 -f board/Corstone-300/fvp_config_u55.txt -a out/cmsis-executorch/SSE-300-U55/Debug/cmsis-executorch.hex --simlimit 60
FVP_MODEL=FVP_Corstone_SSE-300_Ethos-U55 bash .vscode/fvp.sh -f board/Corstone-300/fvp_config_u55.txt -a out/cmsis-executorch/SSE-300-U55/Debug/cmsis-executorch.hex --simlimit 60
The output is similar to:
        Ethos-U version info:
        Arch:       v1.1.0
        MACs/cc:    128
        Cmd stream: v0
ExecuTorch Ethos-U55-128 application: 7608 byte model
Output: 10 element(s): 0.0532 -0.0239 0.0541 0.1064 0.0706 0.0395 0.0881 0.1340 0.0807 0.0064
Test_result: PASS
The runner prints Test_result: PASS when inference returns successfully with a nonempty output list. Check that the preceding line also reports ten output values, as shown.
The runner doesn’t assert the tensor shape, data type, or numerical accuracy. To validate a trained model, compare its outputs against a reference. Use the same input data and a tolerance appropriate to the quantization.
Note
On Windows, the FVP can print warnings indicating that python3.dll is unavailable and that the VIO or VSI bridges are disabled. This headless example doesn’t use those bridges. If the run reaches Test_result: PASS, inference completed successfully.
This run checks that the mixed graph ran successfully. To measure latency or power, benchmark the complete graph on your target hardware, including delegation boundaries and tensor conversions.
What you’ve accomplished
You’ve built and run one ExecuTorch program across three execution paths, and used CMSIS-Executorch to make setup easier.
The supported convolution runs in an Ethos-U55 delegate. The unsupported stride-4 convolution runs on Cortex-M55 through the ExecuTorch wrapper and optimized CMSIS-NN kernel. topk runs through the portable ExecuTorch CPU kernel.
This build uses Ethos-U55 to make one unsupported convolution predictable. The same Pack workflow applies to another Ethos-U target when its delegated graph leaves operations for Cortex-M execution.
To adapt the project, complete the following steps:
  • Replace model/model.py.
  • Provide representative calibration inputs.
  • Preserve or update the tensor interface of the runner.
  • Regenerate the AI layer before rebuilding.
