Understand the solution file
After understanding the CMSIS Packs needed by the project, explore how the project works.
cmsis-executorch-u55.csolution.yml defines the complete Ethos-U55 build context. The target definition in the solution file includes:
target-types:
  - type: SSE-300-U55
    board: V2M-MPS3-SSE-300-FVP
    device: SSE-300-MPS3
    variables:
      - Board-Layer: $SolutionDir()$/board/Corstone-300/Board-U55.clayer.yml
      - AI-Layer: $SolutionDir()$/ai_layer/ai_layer.clayer.yml
SSE-300-U55 is the readable target name of the project. The board and device values identify records supplied by installed Packs. CMSIS-Toolbox uses those identities to resolve startup files, memory information, and device conditions.
The mlops: node in the solution file is the single source for the NPU and Vela target settings:
mlops:
  npu:
    type: Ethos-U55
    macs: 128
  vela:
    system: Ethos_U55_High_End_Embedded
    memory: Shared_Sram
  model:
    clayer: $AI-Layer$
    input-shape: 1x16x16x3
    calibration-samples: 2
cbuild setup resolves this into the *.cbuild-mlops.yml file that’s consumed by create_ai_layer.py. The exporter therefore doesn’t duplicate the NPU configuration of the project.
Follow the layers into the project
cmsis-executorch.cproject.yml owns the application and consumes two layers:
groups:
  - group: App
    files:
      - file: ./src/app_main.cpp
      - file: ./src/arm_embedded_module.cpp
      - file: ./src/arm_embedded_module.hpp
layers:
  - layer: $Board-Layer$
    type: Board
  - layer: $AI-Layer$
    type: AI
Each part has one job:
  • The Board layer supplies Cortex-M55 startup, the memory layout, and standard output. It also provides the Ethos-U55 driver and Corstone-300 initialization.
  • The generated AI layer supplies the embedded model and its exact ExecuTorch and CMSIS-NN component selection.
  • The App group initializes ExecuTorch, creates an input tensor, runs one inference, and prints the ten output values.
The Fixed Virtual Platform (FVP) configuration in board/Corstone-300/fvp_config_u55.txt describes the simulated hardware. It’s separate from the Board layer because one configures the simulator, while the other builds software for the simulated target.
See how the PTE enters the firmware
The AI-layer directory now contains the following related model files:
ai_layer/model.pte
ai_layer/model_pte.c
ai_layer/model_pte.h
model.pte is the serialized ExecuTorch program. model_pte.c contains the same bytes represented as a C array. This is why it appears to be a long list of numbers. Embedding the bytes lets a bare-metal system load the program without a filesystem.
src/app_main.cpp includes model_pte.h, wraps a deterministic 1 x 16 x 16 x 3 input buffer as an ExecuTorch tensor, and calls the runtime. The runtime follows the PTE execution plan. It invokes the Ethos-U backend for the delegate and CPU kernels for the remaining operations.
The runner doesn’t need model-specific edits because the adapted model preserves the original input shape and ten-value output. A different model shape or output contract would need corresponding changes in app_main.cpp.
You’ve traced the ready-made project from target selection to the embedded PTE. The repository removes board bring-up work while keeping the CMSIS structure visible and reusable.
Next, you’ll compile these parts, verify which Pack sources were used, and run the image on the Corstone-300 FVP.
