Understand what the CMSIS Pack provides
After producing a model-specific AI layer using the CMSIS-ExecuTorch workflow, inspect what the CMSIS Pack provides to this implementation.
The ExecuTorch CMSIS Pack is a source Pack, not a prebuilt runtime library. The Pack supplies the ExecuTorch runtime, registration code, backends, and operators as selectable CMSIS components.
A .pack file is a ZIP-compatible archive. Its Pack Description file (PDSC) records component names, source files, dependencies, versions, and conditions.
CMSIS-Toolbox uses that metadata to add only the chosen components to the application build. A CMSIS project can select only the components required by its lowered graph instead of maintaining one large source list. Arm Compiler then compiles those sources for the Cortex-M55 target with the rest of the project.
See which Packs were resolved
CMSIS-Toolbox has already acquired the software Packs needed by the project. Inspect the generated Pack lock:
cat cmsis-executorch-u55.cbuild-pack.yml
Get-Content .\cmsis-executorch-u55.cbuild-pack.yml
Among the resolved entries, you can see the two Packs responsible for the mixed model:
        - resolved-pack: ARM::CMSIS-NN@8.0.0
- resolved-pack: PyTorch::ExecuTorch@1.5.1
They have different responsibilities:
  • PyTorch::ExecuTorch@1.5.1 supplies the ExecuTorch runtime, Ethos-U backend, and Cortex-M operator wrappers. It also supplies registration code and portable operators.
  • ARM::CMSIS-NN@8.0.0 supplies the optimized neural-network kernels that are called by the Cortex-M convolution wrapper.
The Pack lock records exact resolved versions so that later builds don’t silently move to newer installed Packs.
Trace the graph into the AI layer
The AI layer is a generated CMSIS software layer that embeds the model. It declares the runtime, backends, operators, and libraries needed to run the model.
Open the AI layer generated from the .pte operator list:
cat ai_layer/ai_layer.clayer.yml
Get-Content .\ai_layer\ai_layer.clayer.yml
Its component list includes:
components:
  - component: Machine Learning:ExecuTorch:Runtime
  - component: Machine Learning:ExecuTorch:Kernel Utils
  - component: Machine Learning:ExecuTorch:Kernel Registration
  - component: Machine Learning:ExecuTorch:Backend EthosU
  - component: Machine Learning:ExecuTorch Operators:Cortex-M dequantize_per_tensor
  - component: Machine Learning:ExecuTorch Operators:Cortex-M quantize_per_tensor
  - component: Machine Learning:ExecuTorch Operators:Cortex-M quantized_conv2d
  - component: Machine Learning:ExecuTorch Operators:Cortex-M transpose
  - component: Machine Learning:ExecuTorch Operators:Portable topk
  - component: ARM::CMSIS:NN Lib
This file is the handover between model export and firmware build:
Export resultSelected component
Ethos-U delegateBackend EthosU
Cortex-M convolutionCortex-M quantized_conv2d and ARM::CMSIS:NN Lib
Quantized boundaries and layout changesMatching Cortex-M components
Portable topkPortable topk
The runtime, kernel utilities, and registration components provide the common machinery needed to load the .pte and dispatch its operators.
You’ll also see ARM_NN_ENABLE_F32 and ARM_NN_ENABLE_F16 definitions in the generated layer. CMSIS-NN 8.0.0 needs them because its Pack component compiles optional floating-point source files.
The fallback convolution in this model remains INT8. These definitions don’t change its data type.
You’ve followed graph targets into two versioned source Packs and a concrete component list. Pack acquisition, dependency resolution, and component selection are now one connected workflow rather than separate downloads.
Next, you’ll see how the reusable CMSIS project combines this generated AI layer with the Corstone-300 board and application layers.
