Start with only Cortex-M
Before you see fallback from an Ethos-U, you’ll see what running a model exclusively on Cortex-M looks like.
Not every microcontroller has an onboard NPU, so some use-cases will involve running TinyML directly on the CPU. In such a case, any optimizations can be the vital difference between functional performance and an impractical application.
See how the export script lowers the graph
Note
The ExecuTorch Cortex-M backend is in beta in the 1.5 release that’s used for these steps. Validation covers MLPerf Tiny models and MobileNetV2. It combines optimized CMSIS-NN implementations with portable FP32 operators for operations outside its accelerated coverage. For supported operators and limitations, see the Cortex-M backend documentation .
The exporter first prepares and converts the model with CortexMQuantizer:
quantizer = CortexMQuantizer()
prepared = prepare_pt2e(captured_graph, quantizer)
for calibration_input in calibration_inputs:
    prepared(calibration_input)
quantized_model = convert_pt2e(prepared)
quantized_exported_program = torch.export.export(quantized_model, example_inputs)
The prepared model is run with both calibration samples to measure activation ranges. convert_pt2e() uses those ranges to choose quantization parameters and insert the operations that move values between FP32 and INT8.
The exporter converts the quantized program to the ExecuTorch Edge dialect and applies the Cortex-M pass manager:
edge_program_manager = to_edge(
    quantized_exported_program,
    compile_config=EdgeCompileConfig(_check_ir_validity=False)
edge_program_manager._edge_programs["forward"] = CortexMPassManager(
    edge_program_manager.exported_program(), use_explicit_layout=True
).transform()
This step rewrites supported patterns as cortex_m.* operators. Unsupported operations, including aten.topk, remain in the portable graph.
The Cortex-M backend is broader than CMSIS-NN. In this model, the quantized convolutions use CMSIS-NN. Quantize and dequantize use Cortex-M operators with Arm Helium vector implementations. A cortex_m.* target therefore means that the Cortex-M backend owns the operator, not necessarily that CMSIS-NN implements it.
Important
The Cortex-M backend isn’t a delegate. Delegation replaces a graph region with a call to a separately compiled backend. Cortex-M lowering instead rewrites supported patterns as registered cortex_m.* operators that the ExecuTorch runtime dispatches normally. You won’t see an executorch_call_delegate node until you add the Ethos-U partitioner.
Export the model for Cortex-M
Use the provided script to lower the model to Cortex-M only, by specifying --mode cortex-m:
python export_cortex_m_fallback.py \
  --mode cortex-m \
  --model-file model/model.py \
  --output-dir artifacts
python .\export_cortex_m_fallback.py `
  --mode cortex-m `
  --model-file model/model.py `
The expected output is:
        Relevant targets before Cortex-M lowering:
aten.convolution.default: 2
aten.topk.default: 1
Relevant targets after Cortex-M lowering:
cortex_m.dequantize_per_tensor.default: 2
cortex_m.quantize_per_tensor.default: 2
cortex_m.quantized_conv2d_nhwc.default: 2
cortex_m.transpose.default: 1
Before lowering, the graph contained two general convolution operations: stride-1 and stride-4. The aten prefix identifies the PyTorch ATen operator namespace. These operators describe the computation, but not the hardware or kernel that will perform it. Lowering replaces both with cortex_m.quantized_conv2d_nhwc, an INT8 convolution using NHWC layout.
aten.topk is unchanged, so it will use the portable CPU kernel. The cortex_m.quantize_* and cortex_m.dequantize_* operators mark boundaries between floating-point (FP32) and INT8 regions.
You’ve seen how Cortex-M lowering replaces supported patterns with optimized Cortex-M operators. The convolutions use CMSIS-NN, quantize and dequantize use Helium vector implementations, and topk remains an ExecuTorch portable kernel.
Next, you’ll see how CMSIS-NN provides optimized CPU fallback when deploying a model to an Ethos-U NPU. The resulting graph combines Ethos-U delegation, CMSIS-NN-backed Cortex-M operators, and a portable CPU kernel.
