Build an OpenCV YOLOX pipeline to benchmark KleidiCV preprocessing
Understand YOLOX and KleidiCV in the detection pipeline
Build OpenCV with and without KleidiCV
Prepare the YOLOX model and test image
Compile and run YOLOX static-image detection
Evaluate KleidiCV preprocessing and pipeline performance
Check the arm64 environment
Confirm that the board runs a 64-bit Arm userspace:
uname -m
The expected output is:
aarch64
Record the operating system, kernel, CPU topology, and CPU features:
cat /etc/os-release
uname -r
lscpu
Keep this information with your benchmark results. KleidiCV selects supported implementations for the available CPU features.
The reference measurements listed in this Learning Path were collected on a Radxa Orion O6 running Debian 12. The board has eight Cortex-A720 CPUs and four Cortex-A520 CPUs. You can use another arm64 Linux system, but CPU topology, supported extensions, and performance results will differ.
Install the build tools
Install the compiler, CMake, Ninja, Git, and image codec development packages:
sudo apt update
sudo apt install -y \
build-essential \
ca-certificates \
cmake \
file \
git \
libjpeg-dev \
libpng-dev \
libtiff-dev \
ninja-build \
pkg-config \
util-linux \
wget
Record the compiler and CMake versions:
c++ --version
cmake --version
Use GCC 10 or later, or Clang 12 or later. If compilation exhausts memory, reduce the --parallel value in the build commands.
Download OpenCV
Create a workspace and check out OpenCV 4.13.0:
mkdir -p ~/opencv-kleidicv-lab
cd ~/opencv-kleidicv-lab
git clone --branch 4.13.0 --depth 1 https://github.com/opencv/opencv.git
Download KleidiCV 26.06
Clone the KleidiCV 26.06 release:
git clone --branch 26.06 --depth 1 \
https://gitlab.arm.com/kleidi/kleidicv.git
Confirm the selected release:
git -C kleidicv describe --tags --exact-match
26.06
OpenCV 4.13.0 downloads KleidiCV 0.7.0 when KLEIDICV_SOURCE_PATH isn’t provided. For the Learning Path, KleidiCV 26.06 is explicitly selected. This is because KleidiCV 26.06 supports the three-channel, arbitrary-ratio resize used by the letterbox stage.
Both builds use the same OpenCV source tree, compiler, and common CMake options. The intended difference is enabling KleidiCV with its default dispatch policy.
Leave OpenCV 4.13.0 unpatched in both builds. The KleidiCV 26.06 OpenCV integration patch adds a copyMakeBorder() Hardware Acceleration Layer (HAL) hook that’s absent from this OpenCV release. You’ll compare preprocessing without that patch, so padding remains an OpenCV operation. Applying the patch creates a different test and requires new measurements.
Build the baseline OpenCV installation
Configure a baseline OpenCV installation without KleidiCV:
cmake -S opencv -B build-baseline -G Ninja \
-DCMAKE_BUILD_TYPE=Release \
-DCMAKE_INSTALL_PREFIX=$HOME/opencv-kleidicv-lab/install-baseline \
-DBUILD_LIST=core,imgproc,imgcodecs,dnn \
-DBUILD_EXAMPLES=OFF \
-DBUILD_opencv_apps=OFF \
-DBUILD_PERF_TESTS=OFF \
-DBUILD_TESTS=OFF \
-DBUILD_SHARED_LIBS=ON \
-DWITH_IPP=OFF \
-DWITH_OPENCL=OFF \
-DWITH_KLEIDICV=OFF
Build and install the baseline:
cmake --build build-baseline --parallel "$(nproc)"
cmake --install build-baseline
List the installed OpenCV libraries:
find install-baseline/lib -maxdepth 1 -type l -name 'libopencv_*.so' \
| sort
install-baseline/lib/libopencv_core.so
install-baseline/lib/libopencv_dnn.so
install-baseline/lib/libopencv_imgcodecs.so
install-baseline/lib/libopencv_imgproc.so
Confirm the baseline setting:
grep '^WITH_KLEIDICV' build-baseline/CMakeCache.txt
WITH_KLEIDICV:BOOL=OFF
Build OpenCV with KleidiCV
Configure the second build with KleidiCV enabled. Leave its dispatch options at their defaults:
cmake -S opencv -B build-kleidicv-default -G Ninja \
-DCMAKE_INSTALL_PREFIX=$HOME/opencv-kleidicv-lab/install-kleidicv-default \
-DBUILD_TESTS=OFF \
-DWITH_IPP=OFF \
-DWITH_OPENCL=OFF \
-DWITH_KLEIDICV=ON \
-DKLEIDICV_SOURCE_PATH=$HOME/opencv-kleidicv-lab/kleidicv
Build and install it:
cmake --build build-kleidicv-default --parallel "$(nproc)"
cmake --install build-kleidicv-default
Confirm that KleidiCV is enabled:
grep '^WITH_KLEIDICV' build-kleidicv-default/CMakeCache.txt
WITH_KLEIDICV:BOOL=ON
Confirm that the KleidiCV libraries were built:
find build-kleidicv-default/3rdparty/lib -maxdepth 1 -type f \
-name 'libkleidicv*.a' -printf '%f\n' | sort
libkleidicv.a
libkleidicv_hal.a
libkleidicv_thread.a
You’ve created baseline and default KleidiCV 26.06 OpenCV installations from the same unpatched source.
Next, you’ll download the YOLOX model and a static test image.
