On the FRDM i.MX93, you deploy ExecuTorch as two cooperating artifacts:
| Component | Role in Deployment | What It Contains | Why It’s Required |
.pte file (e.g., mobilenetv2_u65.pte) | The model itself, exported from ExecuTorch | Serialized and quantized operator graph + weights + metadata | Provides the neural network to be executed |
executor_runner (binary
ELF
file) | The runtime program that runs the .pte file | C++ application that loads the .pte, prepares buffers, and calls the NPU or CPU backend | Provides the execution engine and hardware access logic |
│ Host Development │
│ (e.g., Linux or macOS+Docker) │
│ [Model export / compilation with ExecuTorch] │
│ │ executor_runner │ │ .pte │ │
│ │ (ELF binary) │ │ (model) │ │
│ SCP/serial transfer │
│ NXP i.MX93 Embedded Board │
│ │ executor_runner (runtime binary) │ │
│ │ │ Load .pte (model) │ │ │
│ │ │ Initialize hardware (CPU/NPU) │ │ │
│ │ │ Perform inference │ │ │
│ │ │ Output results │ │ │
ExecuTorch runtime deployment to an embedded systemThis section shows you how to build .pte files for the Ethos-U65 NPU.
You compile two models:
The .pte file is the handoff point between “host build time” and “device run time”. In the later deployment steps, Linux is responsible for loading firmware, and the Cortex-M33 firmware is responsible for loading and executing the .pte using the Ethos-U delegate.
This script creates a basic addition model, quantizes it, and compiles it for the Ethos-U65. Use this to verify that your environment is correctly configured.
Create the compilation script:
cat > compile_u65.py << 'EOF'
import torch
from torch.export import export
from torchao.quantization.pt2e.quantize_pt2e import convert_pt2e, prepare_pt2e
from executorch.backends.arm.ethosu import EthosUCompileSpec, EthosUPartitioner
from executorch.backends.arm.quantizer import EthosUQuantizer, get_symmetric_quantization_config
from executorch.exir import to_edge_transform_and_lower
class SimpleAdd(torch.nn.Module):
def forward(self, x, y):
return x + y
model = SimpleAdd().eval()
example_inputs = (torch.ones(1, 1, 1, 1), torch.ones(1, 1, 1, 1))
print("[1/5] Exporting...")
exported_program = export(model, example_inputs)
print("[2/5] Creating U65 spec...")
compile_spec = EthosUCompileSpec(
target="ethos-u65-256",
system_config="Ethos_U65_High_End",
memory_mode="Shared_Sram",
print("[3/5] Quantizing...")
quantizer = EthosUQuantizer(compile_spec)
quantizer.set_global(get_symmetric_quantization_config())
prepared = prepare_pt2e(exported_program.graph_module, quantizer)
prepared(*example_inputs)
quantized = convert_pt2e(prepared)
print("[4/5] Lowering to U65...")
quantized_program = export(quantized, example_inputs)
edge = to_edge_transform_and_lower(quantized_program, partitioner=[EthosUPartitioner(compile_spec)])
pte = edge.to_executorch()
print("[5/5] Saving...")
with open("model_u65.pte", "wb") as f:
f.write(pte.buffer)
print(f"SUCCESS: model_u65.pte ({len(pte.buffer)/1024:.1f} KB)")
EOF
Run the compilation:
python3 compile_u65.py
If successful, you see output similar to:
[1/5] Exporting...
[3/5] Quantizing...
[5/5] SUCCESS! Saved: model_u65.pte
File size: 3.9 KB
This script compiles the MobileNet V2 computer vision model for the Ethos-U65. MobileNet V2 is a convolutional neural network (CNN) used for image classification and object detection.
MobileNet V2 uses export_for_training() instead of export() because it contains batch normalization layers that must be traced in training mode before quantization can fuse them. The simple add model above has no such layers, so export() is sufficient.
Create the MobileNet V2 compilation script:
cat > compile_mv2_u65.py << 'EOF'
import torch
from torch.export import export, export_for_training
from torchvision.models import mobilenet_v2, MobileNet_V2_Weights
print("[1/5] Loading MobileNetV2...")
model = mobilenet_v2(weights=MobileNet_V2_Weights.IMAGENET1K_V1).eval()
example_inputs = (torch.randn(1, 3, 224, 224),)
print("[2/5] Exporting...")
exported_program = export_for_training(model, example_inputs).module()
print("[3/5] Quantizing for U65...")
prepared = prepare_pt2e(exported_program, quantizer)
with open("mobilenetv2_u65.pte", "wb") as f:
f.write(pte.buffer)
print(f"SUCCESS: mobilenetv2_u65.pte ({len(pte.buffer)/1024/1024:.2f} MB)")
EOF
python3 compile_mv2_u65.py
If successful, you see the Vela compiler summary indicating 100% NPU utilization. This is an important bring-up signal because it shows the graph was lowered onto the Ethos-U path rather than falling back to CPU execution.
Network summary for out
Accelerator configuration Ethos_U65_256
System configuration Ethos_U65_High_End
Memory mode Shared_Sram
CPU operators = 0 (0.0%)
NPU operators = 117 (100.0%)
Neural network macs 300838272 MACs/batch
SUCCESS: mobilenetv2_u65.pte (3.34 MB)
Verify that the .pte file was generated:
ls -la mobilenetv2_u65.pte
The executor_runner firmware loads .pte models from a fixed DDR address (0xC0000000). The model must be written to DDR before Linux boots, using U-Boot.
Copy the .pte files out of the Docker container:
docker cp <container-id>:/root/executorch/model_u65.pte .
docker cp <container-id>:/root/executorch/mobilenetv2_u65.pte .
Replace <container-id> with your Docker container ID.
Write the .pte files to the first partition of the SD card so U-Boot can load them:
sudo mount /dev/sdX1 /mnt
sudo cp model_u65.pte mobilenetv2_u65.pte /mnt/
sudo umount /mnt
cp model_u65.pte mobilenetv2_u65.pte /Volumes/<SD_CARD_NAME>/
For the commands above:
/dev/sdX1 with your SD card’s first partition.<SD_CARD_NAME> with the mounted volume name.In this section you’ve:
.pte file with 100% NPU operator coverageWith both .pte files ready, you can now build the Cortex-M33 executor_runner firmware that will load and execute them.
