This section is where the heterogeneous system comes together. Linux on the application cores manages the lifecycle of Cortex-M33 through RemoteProc, and your Cortex-M33 firmware brings up ExecuTorch and the Ethos-U65 delegate.
Your success criteria is simple and observable: the remoteproc trace buffer shows a completed inference run with no bus errors.
Before deploying, verify the following on your FRDM-IMX93 board:
Ethos-U kernel driver is loaded. The Linux ethosu driver must be bound so the NPU is powered and clocked:
ls /dev/ethosu*
__output__/dev/ethosu0
If /dev/ethosu0 doesn’t exist, the NPU isn’t powered and the firmware will hang at NPU initialization.
DDR memory is reserved for the CM33. The NXP BSP reserves two DDR regions by default:
reserved-memory {
model@c0000000 {
reg = <0 0xc0000000 0 0x400000>; /* 4MB for .pte model */
no-map;
ethosu_region@A8000000 {
reg = <0 0xa8000000 0 0x8000000>; /* 128MB for NPU working memory */
no-map;
From the Executorch_runner_cm33 project, copy both the firmware and the .pte model to the board:
scp debug/executorch_runner_cm33.elf root@<board-ip>:/lib/firmware/
scp mobilenetv2_u65.pte root@<board-ip>:/tmp/
SSH into the board for the remaining steps:
ssh root@<board-ip>
Replace <board-ip> with your board’s actual IP address.
The executor_runner firmware reads the .pte model from DDR at address 0xC0000000. Write the model into DDR using /dev/mem:
python3 -c "
import mmap, os
pte = open('/tmp/mobilenetv2_u65.pte', 'rb').read()
fd = os.open('/dev/mem', os.O_RDWR | os.O_SYNC)
m = mmap.mmap(fd, len(pte), mmap.MAP_SHARED, mmap.PROT_WRITE, offset=0xC0000000)
m.write(pte)
m.close()
__output__os.close(fd)
print(f'Wrote {len(pte)} bytes to 0xC0000000')
Wrote 3507872 bytes to 0xC0000000
You can also load the model via U-Boot if the .pte file is on the SD card’s first partition. At the U-Boot prompt, run fatload mmc 0:1 0xc0000000 mobilenetv2_u65.pte followed by boot. The model remains in DDR across Linux boot because the region is marked no-map.
Start the Cortex-M33 firmware through RemoteProc. RemoteProc is the control plane for this platform: it gives you a consistent way to stop, replace, and start the Cortex-M33 image without manually resetting the system.
echo stop > /sys/class/remoteproc/remoteproc0/state
echo executorch_runner_cm33.elf > /sys/class/remoteproc/remoteproc0/firmware
echo start > /sys/class/remoteproc/remoteproc0/state
sleep 15
cat /sys/kernel/debug/remoteproc/remoteproc0/trace0
If no firmware is running, the stop command prints an error. That is expected and can be ignored.
You should see output similar to:
NPU config match
NPU arch match
cmd_end_reached 0x1
bus_status_error 0x0
1 inferences finished
Output[0]: dtype=6, numel=1000, nbytes=4000
Program complete, exiting.
The key indicators of a successful inference run:
| Output | Meaning |
NPU config match | The compiled model’s NPU configuration matches the hardware |
NPU arch match | The compiled model’s architecture version matches the hardware |
cmd_end_reached 0x1 | The NPU executed all 116 operators in the command stream |
bus_status_error 0x0 | No AXI bus errors during NPU memory access |
numel=1000 | MobileNet V2 output: 1000 ImageNet classification scores (one per class) |
The model runs with uninitialized input data, so the output scores don’t correspond to a real image classification. To get meaningful predictions, feed a real 224x224 RGB image as input.
If the trace buffer shows Program identifier '' != expected 'ET12', the .pte model wasn’t loaded into DDR at 0xC0000000. Reload the model using the steps above.
The executor_runner runs inference once when the firmware starts. To re-run, reload the firmware:
sleep 2
sleep 15
The trace buffer resets at the start of each firmware load, so you’ll always see fresh output.
In this section:
Next, you can iterate on .pte models (and measure how operator coverage and model shape affect runtime behavior) while keeping the firmware bring-up path stable.
To deploy a new version of the firmware:
sleep 2
sleep 15
RemoteProc fails to load firmware:
Check that the file exists and has correct permissions:
ls -la /lib/firmware/executorch_runner_cm33.elf
chmod 644 /lib/firmware/executorch_runner_cm33.elf
Program identifier '' != expected 'ET12':
The .pte model is not present at DDR address 0xC0000000. Reload the model using the /dev/mem method or via U-Boot.
Firmware hangs (no trace output):
Verify the Ethos-U kernel driver is loaded:
ls /dev/ethosu*
dmesg | grep ethosu
If /dev/ethosu0 does not exist, the NPU is not powered and the firmware cannot initialize it.
Memory allocation failed for planned buffer:
This occurs when a large model’s activation tensors exceed the DTCM method allocator. The firmware automatically uses DDR for models that need more than 12KB of planned buffers. If you see this error, verify the ethosu_region@A8000000 (128MB) is reserved in the device tree.
BUS FAULT or vtable corruption:
The SDK linker script patch has not been applied. Run the patch script and rebuild:
./patches/apply_patches.sh
cmake --preset debug
cmake --build debug
Firmware crashes after NPU init:
Check kernel logs:
dmesg | grep -i error | tail
This might indicate memory configuration issues. Verify that both DDR regions (0xC0000000–0xC03FFFFF and 0xA8000000–0xAFFFFFFF) are reserved in the device tree.
You’ve completed the full bring-up flow for ExecuTorch on the NXP FRDM i.MX 93. Along the way, you set up a reproducible build environment, compiled two .pte model artifacts targeting the Ethos-U65, built and patched the Cortex-M33 executor_runner firmware, and deployed it through Linux RemoteProc to confirm a successful end-to-end inference run. The remoteproc trace buffer confirmed zero bus errors and full NPU operator coverage, establishing a stable foundation for iterating on models and firmware independently.
