Run MNIST with ExecuTorch and Ethos-U85 on Alif E8
Learn about MNIST and the Alif Ensemble E8 DevKit
Set up the Alif Ensemble E8 DevKit
(Optional) Set up a Docker development environment
(Optional) Export PyTorch model to ExecuTorch format
Prepare ExecuTorch artifacts for the Alif E8 CMSIS project
Create the Alif E8 CMSIS project
Process and copy a sample image into the Alif E8 CMSIS project
Flash and run the project on the Alif Ensemble E8 DevKit
Set up Python image tools
You’ll convert a handwritten digit image into a C header that the firmware can include at build time.
To start, create a Python virtual environment for image preprocessing:
cd ~/mnist_alif
python3 -m venv venv_image_prep
source venv_image_prep/bin/activate
python -m pip install --upgrade pip
python -m pip install numpy pillow
cd ~\mnist_alif
py -m venv venv_image_prep
.\venv_image_prep\Scripts\Activate.ps1
Save your image
Create a directory for the input image and preprocessing script:
mkdir -p ~/mnist_alif/image
cd ~/mnist_alif/image
New-Item -ItemType Directory -Force -Path ~\mnist_alif\image
cd ~\mnist_alif\image
Place a PNG or JPEG image of a handwritten digit in the directory and name it mnist_image.jpg.
Use a simple, centered, high-contrast digit image. The script supports black-on-white and white-on-black images, and automatically converts black-on-white images to MNIST-style white-on-black format.
You can use any of the images within the MNIST dataset on Hugging Face .
Download the preprocessing script
The MNIST model expects one grayscale 28 × 28 image. You’ll use a preprocessing script to resize the image, convert it to grayscale, scale pixel values to the range 0 to 127, and write the result to input_mnist.h.
Download prepare_mnist_image.py into the image directory:
curl -o prepare_mnist_image.py https://raw.githubusercontent.com/arm-education/alif-ethos-u85-npu-mnist/main/prepare_mnist_image.py
Open prepare_mnist_image.py and inspect.
The script defines command-line arguments, checks that the input image exists, then converts the image to 28 × 28 grayscale pixels. It also handles image inversion so black-on-white images can be converted to the white-on-black style used by MNIST.
The key conversion step scales each pixel into a value within the non-negative int8 range (0 to 127) and flattens the output into a one-dimensional array:
pixels = np.clip(np.rint(pixels * 127.0 / 255.0), 0, 127).astype(np.int8)
flat = pixels.reshape(-1)
The generated header will contain a total of 784 values, one for each pixel in the 28 × 28 input image.
Generate the input header
Run the preprocessing script:
python prepare_mnist_image.py mnist_image.jpg --output input_mnist.h
python .\prepare_mnist_image.py .\mnist_image.jpg --output .\input_mnist.h
Verify the generated file:
ls -lh input_mnist.h
head -n 8 input_mnist.h
Get-Item .\input_mnist.h
Get-Content .\input_mnist.h -TotalCount 8
Open input_mnist.h and look at the generated input_mnist array. This is the numeric pixel data that main.cpp passes into the ExecuTorch runner.
Copy the header into the firmware project
Copy input_mnist.h into the application assets directory:
cp ~/mnist_alif/image/input_mnist.h ~/mnist_alif/alif_vscode-template/mnist_executorch/assets/
Copy-Item "$HOME\mnist_alif\image\input_mnist.h" "$HOME\mnist_alif\alif_vscode-template\mnist_executorch\assets\"
Verify that both firmware assets are present:
ls -lh ~/mnist_alif/alif_vscode-template/mnist_executorch/assets/
Get-ChildItem "$HOME\mnist_alif\alif_vscode-template\mnist_executorch\assets"
The output is similar to:
input_mnist.h
mnist_model_data.h
You’ve now converted a test digit image into input_mnist.h and copied it into the firmware project.
Next, you’ll build and flash the application to the Alif Ensemble E8 DevKit.
