Run MNIST with ExecuTorch and Ethos-U85 on Alif E8
Learn about MNIST and the Alif Ensemble E8 DevKit
Set up the Alif Ensemble E8 DevKit
(Optional) Set up a Docker development environment
(Optional) Export PyTorch model to ExecuTorch format
Prepare ExecuTorch artifacts for the Alif E8 CMSIS project
Create the Alif E8 CMSIS project
Process and copy a sample image into the Alif E8 CMSIS project
Flash and run the project on the Alif Ensemble E8 DevKit
Before you begin
The firmware project needs two artifacts:
mnist_ethos_u85.pte: the ExecuTorch model compiled for Ethos-U85et_bundle.tar.gz: ExecuTorch headers and static libraries for the bare-metal Cortex-M build
If you completed the optional sections to train and export the model yourself, these files are already in ~/mnist_alif/executorch-alif/output/.
If you skipped the optional sections and are using the provided .pte file, create the output directory and download the provided artifacts:
mkdir -p ~/mnist_alif/executorch-alif/output
cd ~/mnist_alif/executorch-alif/output
curl -L -o et_bundle.tar.gz https://raw.githubusercontent.com/arm-education/alif-ethos-u85-npu-mnist/main/et_bundle.tar.gz
curl -L -o mnist_ethos_u85.pte https://raw.githubusercontent.com/arm-education/alif-ethos-u85-npu-mnist/main/mnist_ethos_u85.pte
New-Item -ItemType Directory -Force -Path "$HOME\mnist_alif\executorch-alif\output"
cd "$HOME\mnist_alif\executorch-alif\output"
curl.exe -L -o et_bundle.tar.gz https://raw.githubusercontent.com/arm-education/alif-ethos-u85-npu-mnist/main/et_bundle.tar.gz
curl.exe -L -o mnist_ethos_u85.pte https://raw.githubusercontent.com/arm-education/alif-ethos-u85-npu-mnist/main/mnist_ethos_u85.pte
Verify all artifacts are present:
ls -lh ~/mnist_alif/executorch-alif/output/mnist_ethos_u85.pte
ls -lh ~/mnist_alif/executorch-alif/output/et_bundle.tar.gz
Get-Item ~\mnist_alif\executorch-alif\output\mnist_ethos_u85.pte
Get-Item ~\mnist_alif\executorch-alif\output\et_bundle.tar.gz
Convert the model to a C header
The firmware embeds the .pte model as a byte array in flash memory. Use xxd to generate a C header:
xxd -i mnist_ethos_u85.pte > mnist_model_data.h
cd ~\mnist_alif\executorch-alif\output
& "$env:ProgramFiles\Git\usr\bin\xxd.exe" -i mnist_ethos_u85.pte | Set-Content -Encoding ascii mnist_model_data.h
Open the generated header (mnist_model_data.h) and change the first array declaration to the following:
#include <stdint.h>
const uint8_t __attribute__((aligned(16))) mnist_ethos_u85_pte[] = {
The aligned(16) attribute is required because the Ethos-U85 needs the Vela command stream data aligned to 16 bytes. Without aligned(16), the NPU driver will report an alignment error at runtime.
Extract the ExecuTorch bundle
Extract the ExecuTorch headers (from et_bundle.tar.gz) into the VS Code template project:
cd ~/mnist_alif/alif_vscode-template
mkdir -p third_party/executorch
tar -C third_party/executorch -xzf ~/mnist_alif/executorch-alif/output/et_bundle.tar.gz
cd ~\mnist_alif\alif_vscode-template
New-Item -ItemType Directory -Force -Path .\third_party\executorch
tar -C .\third_party\executorch -xzf "$HOME\mnist_alif\executorch-alif\output\et_bundle.tar.gz"
Verify the headers are in place:
ls third_party/executorch/et_bundle/include/executorch/
You should see runtime/ and other directories.
You’re now ready to integrate the model into the VS Code project.
You’ve now prepared the embedded ExecuTorch model (mnist_model_data.h), ExecuTorch headers (third_party/executorch/et_bundle/include), and the static libraries used by the firmware build (third_party/executorch/et_bundle/lib).
Next, you’ll create the MNIST firmware project by duplicating the Blinky example and replacing relevant files to fit the application.
