Run MNIST with ExecuTorch and Ethos-U85 on Alif E8
Learn about MNIST and the Alif Ensemble E8 DevKit
Set up the Alif Ensemble E8 DevKit
(Optional) Set up a Docker development environment
(Optional) Export PyTorch model to ExecuTorch format
Prepare ExecuTorch artifacts for the Alif E8 CMSIS project
Create the Alif E8 CMSIS project
Process and copy a sample image into the Alif E8 CMSIS project
Flash and run the project on the Alif Ensemble E8 DevKit
Download the model files
To export an MNIST PyTorch model to ExecuTorch .pte format, start by downloading the model files.
If you’re using the provided .pte file instead, skip the entire model export section and proceed with
Prepare firmware artifacts
From inside your container, create the model and output directories:
# Create directories (use full paths, not ~)
mkdir -p /home/developer/models
mkdir -p /home/developer/output
Download the model script and the training script:
curl -L -o /home/developer/models/mnist_model.py https://raw.githubusercontent.com/arm-education/alif-ethos-u85-npu-mnist/main/mnist_model.py
curl -L -o /home/developer/models/train_mnist.py https://raw.githubusercontent.com/arm-education/alif-ethos-u85-npu-mnist/main/train_mnist.py
The model script (mnist_model.py) defines a small convolutional network for 28 × 28 grayscale MNIST images. It has two convolution blocks followed by two fully connected layers:
def __init__(self):
super().__init__()
self.conv1 = nn.Conv2d(1, 16, kernel_size=3, stride=1, padding=1)
self.relu1 = nn.ReLU()
self.pool1 = nn.MaxPool2d(kernel_size=2, stride=2)
self.conv2 = nn.Conv2d(16, 32, kernel_size=3, stride=1, padding=1)
self.relu2 = nn.ReLU()
self.pool2 = nn.MaxPool2d(kernel_size=2, stride=2)
# Fully Connected Layers
self.fc1 = nn.Linear(32 * 7 * 7, 64)
self.relu3 = nn.ReLU()
self.fc2 = nn.Linear(64, 10)
The convolution layers extract image features such as strokes, edges, and digit shapes. Each output channel from a convolution is called a feature map.
Layer 1 (fc1) takes in 32 feature maps of size 7 x 7 each, and reduces those values to 64 features. The final layer (fc2) then maps those 64 features to 10 digit scores (0 to 9).
The same file also exposes the objects expected by the ExecuTorch ahead-of-time compiler:
ModelUnderTest = MNISTModel() # PyTorch model to export
ModelInputs = (load_calibration_input(),)
The training script, however, downloads the
MNIST dataset
, normalizes the images, trains the model, and saves the trained weights to /home/developer/models/mnist_model.pth.
Add calibration input
The model is exported with int8 quantization, so the compiler needs a representative MNIST input during export.
This input is not the image that runs on the board. It’s used only to set quantization ranges when generating the .pte file.
Download the calibration sample:
curl -L -o /home/developer/output/sample_one.pt https://raw.githubusercontent.com/arm-education/alif-ethos-u85-npu-mnist/main/sample_one.pt
The downloaded sample contains one normalized MNIST-style grayscale image, saved as a PyTorch tensor (.pt) with shape [1, 1, 28, 28] and type float32.
This allows mnist_model.py to load the exact format it needs without any image preprocessing step.
For production-quality quantization, you’d normally calibrate with a larger and more diverse set of representative inputs. To keep the export flow small and reproducible, you’ll use one sample.
Train the model
Run the training script:
cd /home/developer/models
python3 train_mnist.py --out /home/developer/models/mnist_model.pth --epochs 3
The output shows the test accuracy after each epoch:
epoch=1 test_loss=... test_acc=...
epoch=2 test_loss=... test_acc=...
epoch=3 test_loss=... test_acc=...
saved /home/developer/models/mnist_model.pth
Verify the checkpoint:
ls -lh /home/developer/models/mnist_model.pth
Export to ExecuTorch
Export the trained model to .pte format for Ethos-U85:
cd $ET_HOME
MNIST_LOAD_CHECKPOINT=1 python3 -m examples.arm.aot_arm_compiler --model_name=/home/developer/models/mnist_model.py --delegate --quantize --target=ethos-u85-256 --system_config=Ethos_U85_SYS_DRAM_Mid --memory_mode=Shared_Sram --output=/home/developer/output/mnist_ethos_u85.pte
Use full paths such as /home/developer/models/mnist_model.py. Don’t use ~ in the export command.
The following are the arguments passed in the export command:
MNIST_LOAD_CHECKPOINT=1: loads the trained weights from/home/developer/models/mnist_model.pth.--model_name: points to the PyTorch model definition.--delegate: partitions supported operators for execution on the Ethos-U NPU.--quantize: converts the model for int8 inference.--target=ethos-u85-256: targets an Ethos-U85 configuration with 256 MACs per cycle.--system_configand--memory_mode: select the Vela memory configuration used when compiling the NPU command stream.--output: writes the exported ExecuTorch program.
Vela is Arm’s compiler for Ethos-U NPUs. During export, it prints information about the selected Ethos-U target, memory use, and NPU performance estimates. Review this output to confirm that the model was compiled for the expected ethos-u85-256 target.
At the end, you should see confirmation of the saved .pte file as follows:
PTE file saved as /home/developer/output/mnist_ethos_u85.pte
Build ExecuTorch static libraries
The firmware links against ExecuTorch runtime libraries. Build the bare-metal Cortex-M libraries inside the container:
cd $ET_HOME
source ~/executorch-venv/bin/activate
rm -rf arm_test/cmake-out
bash backends/arm/scripts/build_executorch.sh
This step can take several minutes.
When the build finishes, list the generated static libraries:
find arm_test/cmake-out -type f -name "*.a" | sort
The output is similar to:
libexecutorch.a
libexecutorch_core.a
libexecutorch_delegate_ethos_u.a
libcortex_m_ops_lib.a
libcmsis-nn.a
Package headers and libraries
Bundle the ExecuTorch headers and libraries into et_bundle.tar.gz:
rm -rf /home/developer/output/et_bundle
mkdir -p /home/developer/output/et_bundle
cp -a arm_test/cmake-out/include /home/developer/output/et_bundle/
cp -a arm_test/cmake-out/lib /home/developer/output/et_bundle/
CMSIS_NN_LIB=$(find arm_test/cmake-out -type f -name "libcmsis-nn.a" | head -n 1)
cp "$CMSIS_NN_LIB" /home/developer/output/et_bundle/lib/
tar -C /home/developer/output -czf /home/developer/output/et_bundle.tar.gz et_bundle
Because /home/developer/output is mounted from your host machine, et_bundle.tar.gz is now available on your host at ~/mnist_alif/executorch-alif/output/et_bundle.tar.gz.
Exit Docker:
exit
You’ve now downloaded and trained the MNIST model and exported an int8 ExecuTorch .pte file for the Ethos-U85 NPU. You’ve also built the bare-metal ExecuTorch libraries and packaged the required headers and libraries into et_bundle.tar.gz.
Next, you’ll prepare the model and runtime artifacts for the Alif firmware project.
