Run MNIST with ExecuTorch and Ethos-U85 on Alif E8
Learn about MNIST and the Alif Ensemble E8 DevKit
Set up the Alif Ensemble E8 DevKit
(Optional) Set up a Docker development environment
(Optional) Export PyTorch model to ExecuTorch format
Prepare ExecuTorch artifacts for the Alif E8 CMSIS project
Create the Alif E8 CMSIS project
Process and copy a sample image into the Alif E8 CMSIS project
Flash and run the project on the Alif Ensemble E8 DevKit
Install Docker Desktop
To train and export an MNIST model to ExecuTorch .pte format, you’ll need to create a Docker environment.
If you’re using the provided .pte file, skip the entire Docker setup section and proceed with
Prepare firmware artifacts
. Complete the Docker setup only if you want to train and export the model yourself.
Docker provides an isolated environment with all the build dependencies needed.
Start by downloading and installing Docker Desktop. For more information, see the Docker Desktop install guide .
Verify Docker installation
After installation, start Docker Desktop and verify that Docker is available from your terminal:
docker --version
The output is similar to:
Docker version 24.0.7, build afdd53b
Test Docker is working:
docker run hello-world
Hello from Docker!
This message shows that your installation appears to be working correctly.
Create the Docker workspace
Create a folder for the Docker files, model scripts, and generated output:
cd ~/mnist_alif
mkdir -p executorch-alif/models executorch-alif/output
cd executorch-alif
cd ~\mnist_alif
New-Item -ItemType Directory -Force -Path .\executorch-alif\models, .\executorch-alif\output
cd .\executorch-alif
The directory will be used as follows:
executorch-alif/
├── Dockerfile
├── start-dev.sh # macOS/Linux
├── start-dev.ps1 # Windows
├── models/ # mounted to /home/developer/models
└── output/ # mounted to /home/developer/output
Create the Dockerfile
Create a file named Dockerfile:
touch Dockerfile
code Dockerfile
New-Item -ItemType File -Path .\Dockerfile
notepad .\Dockerfile
Paste the following in the Dockerfile:
FROM ubuntu:22.04
ENV DEBIAN_FRONTEND=noninteractive
RUN apt-get update && apt-get install -y build-essential ca-certificates cmake curl git ninja-build python3 python3-pip python3-venv unzip vim wget xxd xz-utils && rm -rf /var/lib/apt/lists/*
RUN useradd -m -s /bin/bash developer
USER developer
WORKDIR /home/developer
RUN python3 -m venv /home/developer/executorch-venv
RUN /bin/bash -c "source /home/developer/executorch-venv/bin/activate && pip install --upgrade pip setuptools wheel && pip install torch==2.9.0 torchvision==0.24.0 torchaudio==2.9.0 --index-url https://download.pytorch.org/whl/cpu && pip install ethos-u-vela==4.4.1"
ENV VIRTUAL_ENV=/home/developer/executorch-venv
ENV PATH="$VIRTUAL_ENV/bin:$PATH"
CMD ["/bin/bash"]
Build the Docker image
Build the image from the executorch-alif directory:
docker build -t executorch-alif:latest .
The build can take 5 to 10 minutes.
[+] Building 320.5s (12/12) FINISHED
=> [internal] load build definition from Dockerfile
=> => transferring dockerfile: 1.2kB
=> [internal] load .dockerignore
=> => naming to docker.io/library/executorch-alif:latest
Verify the image:
docker images
executorch-alif latest
Create the container startup script
After building the image, create the container startup script:
cat > start-dev.sh << 'EOF'
#!/bin/bash
SCRIPT_DIR="$(cd "$(dirname "${BASH_SOURCE[0]}")" && pwd)"
docker run -it --rm --name executorch-alif-dev -v "${SCRIPT_DIR}/models:/home/developer/models" -v "${SCRIPT_DIR}/output:/home/developer/output" -w /home/developer executorch-alif:latest /bin/bash
EOF
chmod +x start-dev.sh
$ScriptDir = Split-Path -Parent $MyInvocation.MyCommand.Path
docker run -it --rm --name executorch-alif-dev -v "${ScriptDir}/models:/home/developer/models" -v "${ScriptDir}/output:/home/developer/output" -w /home/developer executorch-alif:latest /bin/bash
'@ | Set-Content -Encoding ascii .\start-dev.ps1
Start the development container
Run the script to start the container:
./start-dev.sh
.\start-dev.ps1
You’ll see the following command prompt:
developer@container_ID:~$
You’re now inside the Docker container.
Clone ExecuTorch in the container
Inside the Docker container, clone ExecuTorch v1.0.0:
cd /home/developer
# Clone ExecuTorch
git clone https://github.com/pytorch/executorch.git
cd executorch
# Checkout stable release
git checkout v1.0.0
# Initialize submodules
git submodule sync
git submodule update --init --recursive
Submodule initialization might take 5-10 minutes depending on your connection.
Set the environment variable ET_HOME:
export ET_HOME=/home/developer/executorch
echo 'export ET_HOME=/home/developer/executorch' >> ~/.bashrc
Install Python dependencies
Activate the Python environment and run the installer script:
# Ensure virtual environment is active
source ~/executorch-venv/bin/activate
cd $ET_HOME
# Upgrade pip
# Install ExecuTorch base dependencies
./install_requirements.sh
# IMPORTANT: Install lxml with version compatible with Vela
# Vela 4.4.1 requires lxml>=4.7.1,<6.0.1
pip install 'lxml>=4.7.1,<6.0.1'
Install ExecuTorch
After activating the environment, install ExecuTorch:
cd $ET_HOME
# Install ExecuTorch in editable mode
CMAKE_BUILD_PARALLEL_LEVEL=2 pip install --no-build-isolation -e .
The --no-build-isolation flag is required so ExecuTorch finds the PyTorch installation from install_requirements.sh.
CMAKE_BUILD_PARALLEL_LEVEL=2 limits the number of parallel CMake build jobs during installation. This limit reduces peak memory usage and helps avoid out-of-memory failures.
Verify the installation:
python3 -c "from executorch.exir import to_edge; print('ExecuTorch installed successfully')"
Set up Arm Ethos-U dependencies
Run the ExecuTorch Arm setup script:
cd $ET_HOME
# Run the Arm setup script
./examples/arm/setup.sh --i-agree-to-the-contained-eula
This script sets up the following dependencies:
- TOSA Libraries
- Ethos-U SDK structure
- CMake toolchain files
Create an environment setup script
Create a reusable environment script for future sessions:
cat > $ET_HOME/setup_arm_env.sh << 'EOF'
#!/usr/bin/env bash
if [ -f "$ET_HOME/examples/arm/arm-scratch/setup_path.sh" ]; then
source "$ET_HOME/examples/arm/arm-scratch/setup_path.sh"
fi
if [ -f "$ET_HOME/examples/arm/ethos-u-scratch/setup_path.sh" ]; then
source "$ET_HOME/examples/arm/ethos-u-scratch/setup_path.sh"
fi
export TARGET_CPU=cortex-m55
export ETHOSU_TARGET_NPU_CONFIG=ethos-u85-256
export SYSTEM_CONFIG=Ethos_U85_SYS_DRAM_Mid
export MEMORY_MODE=Shared_Sram
echo "ExecuTorch Arm environment loaded"
echo "ET_HOME: $ET_HOME"
echo "Vela: $(which vela 2>/dev/null || echo not found)"
EOF
chmod +x $ET_HOME/setup_arm_env.sh
echo 'source $ET_HOME/setup_arm_env.sh' >> ~/.bashrc
Verify complete installation
Run all verification checks:
Check Vela compiler
vela --versionThe output is similar to:
4.4.1Check ExecuTorch:
python3 -c "from executorch.exir import to_edge; print('ExecuTorch OK')"The output is similar to:
ExecuTorch OKThen, run a minimal export test to verify the complete setup:
cd $ET_HOME python3 -m examples.arm.aot_arm_compiler --model_name=add --delegate --quantize --target=ethos-u85-256 --output=/home/developer/output/add_ethos_u85.pteThe output is similar to:
Exporting model add... Lowering to TOSA... Compiling with Vela... PTE file saved as add_ethos_u85.pteVerify the
.ptefile was created:ls -lh /home/developer/output/add_ethos_u85.pteThe
outputdirectory is mounted from your host machine, so the file is also available at~/mnist_alif/executorch-alif/output/.
(Optional) Save container state
To preserve your work, you can commit the container to a new image:
# On your host machine (outside Docker)
docker commit executorch-alif-dev executorch-alif:configured
You’ve now created a Docker environment for model export. The container has Python and PyTorch, ExecuTorch, and Ethos-U Vela installed. You’ve also mounted models and output directories on the container for sharing files with the host.
Next, you’ll export a PyTorch model to ExecuTorch .pte format.
