Explore related resources
Give feedback
AI-assisted
Close
Which Raspberry Pi 5 model should I use for this chatbot?
The 8 GB RAM Raspberry Pi 5 model is preferred for exploring an LLM. Smaller memory configurations might restrict the model that you can run.
How do I know my Raspberry Pi OS installation is 64-bit?
Check your system information to confirm the operating system and kernel report a 64-bit build. If not, reinstall Raspberry Pi OS using the 64-bit image.
Can I follow these steps on another Arm Linux computer?
Yes. The instructions apply to other Arm Linux systems with minor modifications where Raspberry Pi–specific steps appear.
How do I choose a Hugging Face model that will run on my Pi?
Compare the model’s size to your available memory and leave headroom for the operating system and Python runtime. Select a model that fits comfortably within your RAM, then assess performance.
What result should I expect when I run the chatbot?
A Python script loads the chosen model and generates text responses in your terminal. If it starts and responds to prompts, your setup is working.
Return to Embedded and Microcontrollers
