What are Arm Fixed Virtual Platforms (FVPs)?
Arm Fixed Virtual Platforms (FVPs) are fast, functional simulation models of Arm hardware. They give you the ability to develop, test, and debug full software stacks. This includes firmware, bootloaders, and operating systems - all without the need for access to physical Arm silicon. FVPs replicate Arm CPU behavior, memory, and peripherals using fast binary translation.
Why use FVPs?
FVPs are ideal for early software development and system debugging.
Developers can use FVPs to do the following tasks:
  • Prototype firmware and OS code before silicon is available
  • Debug complex boot sequences and kernel issues
  • Simulate multi-core systems to analyze performance and thread scheduling
FVPs provide a programmer’s view of the hardware, making them ideal for the following:
  • System bring-up
  • Kernel porting
  • Low-level debug tasks
How can I get access to the Arm FVPs?
You can download prebuilt Armv8-A FVPs at no cost from the Arm Ecosystem Models page.
Available categories include:
  • Architecture
  • Automotive
  • Infrastructure
  • IoT
A popular model is AEMv8-A Base Platform RevC, which simulates generic Armv8.7-A and Armv9-A CPUs and is fully supported by Arm’s open-source reference software stack .
CPU-specific Arm-based FVPs
Some FVPs target specific CPU implementations and include fixed core counts. These are known as CPU FVPs.
Examples include:
  • FVP_Base_Cortex-A55x4
  • FVP_Base_Cortex-A72x4
  • FVP_Base_Cortex-A78x4
  • FVP_Base_Cortex-A510x4+Cortex-A710x4
To use these, request access via support@arm.com .
Set up your environment
This Learning Path uses the open-source Arm reference software stack, which includes the following:
  • Prebuilt Linux images
  • Firmware
  • Configuration files
To get started:
  • Follow the software user guide to download the stack.
  • Set up your toolchain
  • Export environment variables
  • Verify your build dependencies
Once setup is complete, you’ll be ready to boot and debug Linux on your selected Arm FVP model.
