# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/introduction-to-tinyml-on-arm/)
- [Overview](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/introduction-to-tinyml-on-arm/1-overview/)
- [Install ExecuTorch](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/introduction-to-tinyml-on-arm/2-env-setup/)
- [Set up the Corstone-320 FVP](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/introduction-to-tinyml-on-arm/3-env-setup-fvp/)
- [Build a simple PyTorch model](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/introduction-to-tinyml-on-arm/4-build-model/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/introduction-to-tinyml-on-arm/_next-steps/)
## Explore related resources
- [TinyML Brings AI to Smallest Arm Devices](https://newsroom.arm.com/blog/tinyml)
- [Arm Machine Learning Resources](https://www.arm.com/developer-hub/embedded-and-microcontrollers/ml-solutions/getting-started)
- [Arm Developers Guide for Cortex-M Processors and Ethos-U NPU](https://developer.arm.com/documentation/109267/0101)
## Review frequently asked questions
### How do I know the Corstone-320 FVP setup worked?
The setup is successful when the setup scripts complete without errors and the reference package is available for use. At that point, the FVP is ready for software development and validation without a physical board.
### What does installing ExecuTorch enable in this workflow?
ExecuTorch lets you export PyTorch models and prepare them for execution on resource‑constrained Arm targets. It provides the APIs used to convert the example network into an edge‑ready form.
### What file do I create for the example model, and what does it include?
Create `simple_nn.py`, which defines a small feedforward network with two linear layers and a ReLU activation for a classification task. The script also uses `torch.export` and ExecuTorch conversion to generate an edge representation.
### Do I need a physical development board?
No. The Corstone-320 FVP provides a pre-silicon environment to build and test software before hardware is available.
### Which Arm components does the Corstone-320 FVP support?
The FVP includes support for Arm Ethos-U NPUs and Cortex-M processors. It’s designed for AI and machine learning workloads on microcontrollers.
