# Build a simple PyTorch model
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/introduction-to-tinyml-on-arm/)
- [Overview](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/introduction-to-tinyml-on-arm/1-overview/)
- [Install ExecuTorch](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/introduction-to-tinyml-on-arm/2-env-setup/)
- [Set up the Corstone-320 FVP](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/introduction-to-tinyml-on-arm/3-env-setup-fvp/)
- [Build a simple PyTorch model](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/introduction-to-tinyml-on-arm/4-build-model/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/introduction-to-tinyml-on-arm/_next-steps/)
## Define a small neural network using Python
With your development environment set up, you can create a simple PyTorch model to test the setup.
This example defines a small feedforward neural network for a classification task. The model consists of two linear layers with ReLU activation in between.
Use a text editor to create a file named `simple_nn.py` with the following code:
```python
import torch
from torch.export import export
from executorch.exir import to_edge
# Define a simple Feedforward Neural Network
class SimpleNN(torch.nn.Module):
    def __init__(self, input_size, hidden_size, output_size):
        super(SimpleNN, self).__init__()
        self.fc1 = torch.nn.Linear(input_size, hidden_size)
        self.relu = torch.nn.ReLU()
        self.fc2 = torch.nn.Linear(hidden_size, output_size)
    def forward(self, x):
        out = self.fc1(x)
        out = self.relu(out)
        out = self.fc2(out)
        return out
# Create the model instance
input_size = 10   # example input feature size
hidden_size = 5   # hidden layer size
output_size = 2   # number of output classes
model = SimpleNN(input_size, hidden_size, output_size)
# Example input tensor (batch size 1, input size 10)
x = (torch.randn(1, input_size),)
# Add arguments to be parsed by the Ahead-of-Time (AoT) Arm compiler
ModelUnderTest = model
ModelInputs = x
print("Model successfully exported to simple_nn.pte")
## Run the model on the Corstone-320 FVP
The final step is to take the Python-defined model and run it on the Corstone-320 FVP. This was done upon running the `run.sh` script in a previous section. To wrap up the Learning Path, you will perform these steps separately to better understand what happened under the hood. Start by setting some environment variables that are used by ExecuTorch.
```bash
export ET_HOME=$HOME/executorch
export executorch_DIR=$ET_HOME/build
Generate a model in ExecuTorch `.pte` format using the Arm examples. The AoT Arm compiler enables optimizations for devices such as the Grove Vision AI Module V2 and the Corstone-320 FVP. Run the compiler from the ExecuTorch root directory:
```bash
cd $ET_HOME
python -m examples.arm.aot_arm_compiler --model_name=examples/arm/simple_nn.py --delegate --quantize --target=ethos-u85-256 --system_config=Ethos_U85_SYS_DRAM_Mid --memory_mode=Sram_Only
From the Arm Examples directory, you can build an embedded Arm runner with the `.pte` included. This allows you to optimize the performance of your model and ensures compatibility with the CPU kernels on the FVP. Finally, build the ExecuTorch libraries and generate the executable `arm_executor_runner`.
```bash
cmake -S "${ET_HOME}" \
      -B "${executorch_DIR}" \
      --preset arm-baremetal \
      -DCMAKE_BUILD_TYPE=Release
cmake --build "$executorch_DIR" --target install --parallel
cd $HOME/executorch/examples/arm/executor_runner
cmake -S "${ET_HOME}/examples/arm/executor_runner" \
      -B "${ET_HOME}/examples/arm/executor_runner/cmake-out" \
      -DCMAKE_BUILD_TYPE=Release \
      -DCMAKE_TOOLCHAIN_FILE=$ET_HOME/examples/arm/ethos-u-setup/arm-none-eabi-gcc.cmake \
      -DTARGET_CPU=cortex-m85 \
      -DET_PTE_FILE_PATH:PATH=$ET_HOME/simple_nn_arm_delegate_ethos-u85-256.pte \
      -DETHOS_SDK_PATH:PATH=$ET_HOME/examples/arm/ethos-u-scratch/ethos-u \
      -DETHOSU_TARGET_NPU_CONFIG=ethos-u85-256 \
      -DPYTHON_EXECUTABLE=$HOME/executorch-venv/bin/python3 \
      -DSYSTEM_CONFIG=Ethos_U85_SYS_DRAM_Mid
cmake --build $ET_HOME/examples/arm/executor_runner/cmake-out --parallel -- arm_executor_runner
Run the model on Corstone-320:
```bash
FVP_Corstone_SSE-320 \
-C mps4_board.subsystem.ethosu.num_macs=256 \
-C mps4_board.visualisation.disable-visualisation=1 \
-C vis_hdlcd.disable_visualisation=1                \
-C mps4_board.telnetterminal0.start_telnet=0        \
-C mps4_board.uart0.out_file='-'                    \
-C mps4_board.uart0.shutdown_on_eot=1               \
-a "$ET_HOME/examples/arm/executor_runner/cmake-out/arm_executor_runner"
> **Note**: The argument `mps4_board.visualisation.disable-visualisation=1` disables the FVP GUI and can speed up launch time.
Observe that the FVP loads the model file.
__output__ telnetterminal0: Listening for serial connection on port 5000
__output__ telnetterminal1: Listening for serial connection on port 5001
__output__ telnetterminal2: Listening for serial connection on port 5002
__output__ telnetterminal5: Listening for serial connection on port 5003
__output__ I [executorch:arm_executor_runner.cpp:412] Model in 0x70000000 $
__output__ I [executorch:arm_executor_runner.cpp:414] Model PTE file loaded. Size: 3360 bytes.
You have now set up your environment for TinyML development on Arm and tested a small PyTorch model with ExecuTorch on the Corstone-320 FVP. In the next Learning Path, you learn how to optimize neural networks to run efficiently on Arm.
