What pico-faces is
pico-faces is a compact generative model that produces 128 x 128 RGB face images. It combines a 2.5-million-parameter latent rectified-flow diffusion transformer (DiT) with a small convolutional decoder.
The model provides four conditioned face classes and one unconditional class. The conditioned classes combine the female or male label of the model with a neutral or smiling expression.
Image Alt Text:Diagram showing the pico-faces generation workflow: random latent noise passes through repeated diffusion transformer denoising steps and a decoder to produce a 128 x 128 RGB face on the Alif E8 Cortex-M55 and Ethos-U85. A row of example generated faces illustrates the model output.pico-faces diffusion workflow on the Alif Ensemble E8
The CMSIS-ExecuTorch example that you’ll build re-expresses the model as two ExecuTorch methods:
MethodPurposeExecution target
dit_step(z, c)Predict the velocity used to update the latent imageEthos-U85
decode(z)Convert the final latent image into an RGB faceEthos-U85
Sampling loopGenerate noise, apply guidance, and update the latent imageCortex-M55
The dit_step method uses 16-bit activations and 8-bit weights. The extra activation precision preserves the residual stream of the transformer. The decoder uses 8-bit activations and weights, which reduces its execution time without the same visible quality loss.
Follow the deployment flow
The example uses a CMSIS solution to keep the hardware definition separate from the Python exporter. The workflow has three stages:
  1. CMSIS-Toolbox resolves the DevKit-E8 target and records its Cortex-M55, Ethos-U85, and Vela settings in cmsis-executorch.cbuild-mlops.yml.
  2. create_ai_layer.py quantizes and exports both methods, delegates them to Ethos-U85, and writes the AI layer.
  3. CMSIS-Toolbox builds the application and embeds the ExecuTorch program in the firmware image.
The generated application uses the high-performance Cortex-M55 core at 400 MHz to control sampling. The Ethos-U85 configuration provides 256 multiply-accumulate operations per cycle. The firmware displays each generated face on the DevKit LCD and reports timings through UART4.
A successful workflow run is indicated in three ways:
  • The DevKit LCD displays the generated face.
  • UART output ends with Test_result: PASS.
  • The Ethos-U performance monitoring unit reports cycles and activity for both model methods.
The first image uses a fixed seed and configuration. This makes the boot test repeatable even though the exact Cyclic Redundancy Check (CRC) can change when the model is exported on a different host.
You’ve learned how the Cortex-M55 sampling loop calls two ExecuTorch methods that run on the Ethos-U85 NPU.
Next, you’ll install the host tools and connect the DevKit.
