Generate human faces with a diffusion model on an Alif Ensemble E8
Understand the pico-faces workflow
Set up the development tools and DevKit
Export the pico-faces model for Ethos-U85
Prepare the DevKit for debugging
Generate and validate faces on the DevKit
Before you connect the DevKit, unplug all USB cables before changing any jumpers. Keep JP5 on pins 1–2 and JP7 on pins 3–4, and set SW4 to SEUART.
Connect a USB-C cable to the PRG USB port on the bottom edge of the DevKit. You can confirm that the board has power when its power LED lights.
Clone the CMSIS-ExecuTorch repository using the
hackathon-pico-faces branch. Use the --branch hackathon-pico-faces --single-branch options, then open the workspace in VS Code.Set SW4 to UART4 and open Serial Monitor on the PRG USB port at
115200 baud, eight data bits, no parity, and one stop bit. If the port was open before changing SW4, close and reopen it.From the CMSIS view, select Build, then Debug. Keil Studio starts the J-Link GDB server over SWD and loads the application into MRAM, stopping at
main. Press F5 to continue. Check the displayed face and Test_result: PASS for functional operation. Check for nonzero NPU counters in the UART output to verify Arm Ethos-U85 activity.
