Deploy Edge Impulse models with AWS IoT Greengrass on Arm
Explore Edge Impulse and AWS IoT Greengrass architecture
Select and set up your edge device
Set up your Edge Impulse project
Install AWS IoT Greengrass on your Arm edge device
Store your Edge Impulse API key in AWS Secrets Manager
Create the Edge Impulse Greengrass component
Deploy the component to your edge device
Verify inference and view results
What you’ll create
You’ll create an AWS IoT Greengrass custom component that installs and runs the Edge Impulse Linux Runner service on your device. The component handles the Node.js and libvips prerequisites and manages the Edge Impulse Linux Runner lifecycle: install, run, and shutdown.
The component consists of two parts:
- Artifacts: Shell scripts, stored in Amazon S3, that install dependencies and launch the Edge Impulse Linux Runner.
- Recipe: A YAML file that tells Greengrass where to find the artifacts, what configuration to apply, and how to manage the component lifecycle.
Clone the component repository
Clone the Edge Impulse Greengrass components repository to get the recipe and artifact files:
git clone https://github.com/edgeimpulse/aws-greengrass-components.git
The repository contains the YAML recipe file and the shell script artifacts that you’ll upload to an S3 bucket.
Upload artifacts to Amazon S3
The Greengrass component downloads its artifacts from an S3 bucket at deployment time. You need to create a bucket and upload the shell scripts.
To upload artifacts to a bucket:
- Open the AWS Console and navigate to S3.
- Select Create bucket and give it a name (for example,
my-ei-greengrass-artifacts):
Create an S3 bucket
Inside your new bucket, create the following directory structure:
artifacts/EdgeImpulseServiceComponent/1.0.0/Navigate to the
1.0.0directory in your S3 bucket and select Upload. Upload all four files from the cloned repository’s./artifacts/EdgeImpulseServiceComponent/1.0.0/directory:install.shrun.shlaunch.shstop.sh
After the upload, your S3 bucket should look as follows:
Uploaded artifacts in S3
Customize the component recipe
The recipe YAML file tells Greengrass where to download the artifacts from S3. You need to update it with the name of your S3 bucket.
Open EdgeImpulseLinuxEdge Impulse Linux RunnerServiceComponent.yaml from the cloned repository and replace all occurrences of YOUR_S3_ARTIFACT_BUCKET with the name of your S3 bucket (for example, my-ei-greengrass-artifacts). After making updates, save the file.
Default configuration reference
The recipe file includes a default configuration JSON block. You don’t need to modify these defaults for the Learning Path — they’re overridden at deployment time by the device-specific JSON that you saved during hardware setup. However, understanding each field is useful for troubleshooting and customization.
"node_version": "20.12.1",
"vips_version": "8.12.1",
"device_name": "MyEdgeImpulseDevice",
"launch": "runner",
"sleep_time_sec": 10,
"lock_filename": "/tmp/ei_lockfile_runner",
"gst_args": "__none__",
"eiparams": "--greengrass",
"iotcore_backoff": "5",
"iotcore_qos": "1",
"ei_bindir": "/usr/local/bin",
"ei_sm_secret_id": "EI_API_KEY",
"ei_sm_secret_name": "ei_api_key",
"ei_ggc_user_groups": "video audio input users",
"install_kvssink": "no",
"publish_inference_base64_image": "no",
"enable_cache_to_file": "no",
"ei_poll_sleeptime_ms": 2500,
"ei_local_model_file": "/home/ggc_user/data/currentModel.eim",
"ei_shutdown_behavior": "__none__",
"cache_file_directory": "__none__",
"enable_threshold_limit": "no",
"metrics_sleeptime_ms": 30000,
"default_threshold": 50.0,
"threshold_criteria": "ge",
"enable_cache_to_s3": "no",
"s3_bucket": "__none__"
The following table describes each configuration field:
| Field | Description |
node_version | Version of Node.js to install on the device. |
vips_version | Version of the libvips library to compile and install. |
device_name | Base name for the device in Edge Impulse. A unique suffix is appended automatically to prevent collisions when deploying to multiple devices. |
launch | Service launch type. Leave as runner. |
sleep_time_sec | Wait loop sleep time for the component lifecycle. Leave as default. |
lock_filename | Lock file path for this component. Leave as default. |
gst_args | GStreamer pipeline arguments with spaces replaced by colons. Set per-device during deployment. For example, v4l2src:device=/dev/video0:!:video/x-raw,width=640,height=480:!:videoconvert:!:jpegenc. Use __none__ to disable. |
eiparams | Additional parameters for the Edge Impulse Linux Runner. The --greengrass flag is required. |
iotcore_backoff | Number of inference results to skip between MQTT publications. Controls publication frequency and cost. Set to -1 to publish every result, or a positive number to throttle. |
iotcore_qos | MQTT Quality of Service level. Leave as 1. |
ei_bindir | Installation directory for the Edge Impulse CLI tools. Leave as default. |
ei_sm_secret_id | ID of the secret in AWS Secrets Manager that holds the Edge Impulse API key. The ID must match the secret name that you created, EI_API_KEY. |
ei_sm_secret_name | Key name within the Secrets Manager secret. The name must match the key you created, ei_api_key. |
ei_ggc_user_groups | Linux groups that include the Greengrass service user, ggc_user. For JetPack 6.x and later, add render to the list for GPU access. |
install_kvssink | Set to yes to build and install the KVS sink GStreamer plugin. The default is no. |
publish_inference_base64_image | Set to yes to include a base64-encoded image with each inference result published to MQTT. The default is no. |
enable_cache_to_file | Set to yes to write inference results and associated images to a local directory as paired files (<guid>.json and <guid>.img). The default is no. |
cache_file_directory | Local directory path for cached files when enable_cache_to_file is yes. The default is __none__. |
ei_poll_sleeptime_ms | Polling interval in milliseconds for the long-polling message processor. Leave as default. |
ei_local_model_file | Path to a previously downloaded local model file, .eim. Set to __none__ to download the model from Edge Impulse at runtime. For the Learning Path, set it to /home/ggc_user/data/currentModel.eim. |
ei_shutdown_behavior | Controls Edge Impulse Linux Runner behavior after the model finishes. Set to wait_on_restart to pause after a video file ends and wait for a restart command. The default is __none__. |
enable_threshold_limit | Set to yes to enable the confidence threshold filter. The default is no. |
metrics_sleeptime_ms | Interval in milliseconds between model metrics publications. The default is 30000. |
default_threshold | Confidence threshold value between 0 and 100. Inference results below this threshold are filtered out when enable_threshold_limit is yes. The default is 50.0. |
threshold_criteria | Comparison operator for the threshold filter. Must be one of gt, ge, eq, le, or lt. The default is ge. |
enable_cache_to_s3 | Set to yes to cache inference images and results to an S3 bucket. The default is no. |
s3_bucket | S3 bucket name for cached results when enable_cache_to_s3 is yes. The default is __none__. |
Register the component in Greengrass
With the artifacts in S3 and the recipe updated, register the component in the AWS Console.
To register the component:
- Navigate to AWS IoT Core > Greengrass > Components.
- Select Create component.
- Select Enter recipe as YAML as the input method.
- Clear the default
hello worldYAML from the text box. - Copy and paste the entire contents of your edited
EdgeImpulseLinuxEdge Impulse Linux RunnerServiceComponent.yamlfile. - Select Create component.
Register the custom component
If the recipe format is valid and Greengrass can access the S3 artifacts, the component appears in your custom components list.
You’ve cloned the Edge Impulse component repository and uploaded artifacts to S3. You’ve also customized the recipe with your bucket name, and registered the component in Greengrass.
Next, you’ll create a Greengrass deployment to push this component to your edge device.
