This section shows you how to create a complete sketch that you can upload onto your Arduino Nano RP2040.
You’ll begin by setting up a new sketch in the Arduino IDE, then add the library generated by Edge Impulse. After reviewing a sample program, you’ll upload it to your board to run real-time audio inference and control an LED based on voice commands.
By the end of this section, your board will be able to respond to the words “on” and “off”. It is a simple, but powerful, demonstration of TinyML in action.
To create a new sketch in the Arduino IDE, follow these steps:
setup() and loop(). The setup() function runs once when the program starts, and the loop() function runs continuously after that.setup() and loop(). The setup() function runs once when the program starts, and the loop() function runs continuously after that.To include the library and model in your sketch, go to Sketch > Include Library and select the newly installed Edge Impulse library from the list.
This will add the necessary include statement at the top of your sketch, allowing you to use the functions and classes provided by the Edge Impulse library.
In the example repository, you will find a code snippet named Code_Sample.ino, which is used as a sketch for this project. Before running the code, it’s important to understand what each part does.
Take a few minutes to read through the comments and logic in the sketch before uploading it to your board. The code is available in the example repository, and below is a walk-through of the steps.
This block sets up the core dependencies for running Edge Impulse inference on audio input. It includes the necessary libraries and defines a structure inference_t that holds the audio buffer and relevant state needed to manage sampling and inferencing.
#include <Name_of_your_library_inferencing.h> // Include the Edge Impulse inference SDK for running the model
#include <PDM.h> // Include the Pulse Density Modulation (PDM) library for audio input
// Define a structure to store inference-related audio data
typedef struct {
int16_t *buffer; // Pointer to the audio sample buffer (16-bit signed integers)
uint8_t buf_ready; // Flag to indicate if the buffer is ready for inference (1 = ready)
uint32_t buf_count; // Number of audio samples currently in the buffer
uint32_t n_samples; // Total number of samples required for a complete inference
} inference_t;
This block declares and initializes global variables used to store inference data, raw audio samples, a debug flag, and a recording readiness flag. These variables coordinate the data collection and inference process.
static inference_t inference; // Global instance of the inference structure to manage audio data
static signed short sampleBuffer[2048]; // Buffer to temporarily store raw audio samples (16-bit signed)
static bool debug_nn = false; // Flag to enable/disable detailed neural network debug output
static volatile bool record_ready = false; // Flag indicating when the system is ready to start recording (volatile due to use in ISR)
## Setup Function for Initializing the Serial and Microphone
The `setup()` function is called once when the program starts. It initializes the serial communication, sets up the LED pin, prints out configuration details, and starts the microphone buffer for audio data collection.
```c
// DEFINE THE MACRO FOR YOUR LED PIN HERE
# define LED_PIN 2 // Update the pin number to match the digital pin you intend to use for the LED
void setup() {
Serial.begin(115200); // Start serial communication at 115200 baud rate
while (!Serial); // Wait for the serial port to be ready
pinMode(LED_PIN, OUTPUT); // Configure the LED pin as output (to control an LED)
Serial.println("Edge Impulse Inferencing Demo"); // Print a startup message to the serial monitor
// Print inference configuration settings
ei_printf("Inferencing settings:\n");
ei_printf("\tInterval: ");
ei_printf_float((float)EI_CLASSIFIER_INTERVAL_MS); // Print the interval between inference cycles
ei_printf(" ms.\n");
ei_printf("\tFrame size: %d\n", EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE); // Print frame size for DSP processing
ei_printf("\tSample length: %d ms.\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT / 16); // Print sample length in ms
ei_printf("\tNo. of classes: %d\n", sizeof(ei_classifier_inferencing_categories) / sizeof(ei_classifier_inferencing_categories[0])); // Print the number of classes
// Start the microphone buffer for audio input and check if it was successful
if (!microphone_inference_start(EI_CLASSIFIER_RAW_SAMPLE_COUNT)) {
ei_printf("ERR: Could not allocate audio buffer\n"); // Error message if allocation fails
return; // Exit the setup function
The macro #define LED_PIN 2 specifies the pin number to which the LED is connected. You can change this value to any available digital pin on your board.
The loop() function runs continuously after setup(). It performs the inference process, including recording audio, running the classifier, and controlling an LED based on the model’s prediction.
void loop() {
ei_printf("Starting inferencing in 2 seconds...\n"); // Print message indicating a 2-second delay before starting inference
delay(2000); // Wait for 2 seconds before beginning the next operation
ei_printf("Recording...\n"); // Print message to indicate that recording is starting
if (!microphone_inference_record()) { // Start recording audio data
ei_printf("ERR: Failed to record audio...\n"); // Print error if recording fails
return; // Exit loop if recording fails
ei_printf("Recording done\n"); // Print message after recording is done
// Set up the signal structure to hold the audio data and provide a function for data retrieval
signal_t signal;
signal.total_length = EI_CLASSIFIER_RAW_SAMPLE_COUNT; // Set the total length of the recorded signal
signal.get_data = microphone_audio_signal_get_data; // Specify the function to get the data from the microphone
ei_impulse_result_t result = {0}; // Initialize the result structure to store the classifier's output
// Run the classifier continuously on the signal and store the results
if (run_classifier_continuous(&signal, &result, debug_nn) != EI_IMPULSE_OK) {
ei_printf("ERR: Failed to run classifier\n"); // Print error if classifier fails
return; // Exit loop if classifier fails
print_inference_result(result); // Print the inference results (e.g., classification)
// LED logic based on classifier result (turn on/off the LED based on inference)
for (uint16_t i = 0; i < EI_CLASSIFIER_LABEL_COUNT; i++) {
// If the classification result is "on", turn the LED on
if (strcmp(ei_classifier_inferencing_categories[i], "on") == 0 && result.classification[i].value > 0.5) {
digitalWrite(LED_PIN, HIGH); // Turn LED on
// If the classification result is "off", turn the LED off
else if (strcmp(ei_classifier_inferencing_categories[i], "off") == 0 && result.classification[i].value > 0.4) {
digitalWrite(LED_PIN, LOW); // Turn LED off
The values 0.5 and 0.4 in the code above represent threshold levels that you can adjust to test and optimize the performance of the machine learning model. These thresholds determine when the LED should turn on or off based on the model’s inference results.
In this example, the LED will turn on if the model predicts the “on” label with a confidence of 50% or higher (i.e., a threshold of 0.5). Similarly, it will turn off if the model predicts the “off” label with a confidence of 40% or higher (i.e., a threshold of 0.4).
You are free to modify these threshold values to better suit your application or improve model response.
The pdm_data_ready_inference_callback() function is triggered when the Pulse Density Modulation (PDM) buffer is full. It reads the available audio data and stores it in the inference buffer for processing.
/* PDM buffer full callback */
static void pdm_data_ready_inference_callback(void) {
int bytesAvailable = PDM.available(); // Check how many bytes are available in the PDM buffer
int bytesRead = PDM.read((char *)&sampleBuffer[0], bytesAvailable); // Read the available data into the sampleBuffer
// If the buffer is not yet full and recording is ready, store the incoming data in the inference buffer
if ((inference.buf_ready == 0) && (record_ready == true)) {
// Loop through the bytes read and store them in the inference buffer
for (int i = 0; i < bytesRead >> 1; i++) {
inference.buffer[inference.buf_count++] = sampleBuffer[i]; // Store each 16-bit audio sample
if (inference.buf_count >= inference.n_samples) { // Check if enough samples have been collected
inference.buf_count = 0; // Reset the sample count
inference.buf_ready = 1; // Mark the buffer as ready for inference
break; // Exit loop once the buffer is full
Allocates memory for audio sampling, configures the PDM microphone, and prepares the system to begin audio inference.
static bool microphone_inference_start(uint32_t n_samples) {
// Allocate memory to store the audio samples
inference.buffer = (int16_t *)malloc(n_samples * sizeof(int16_t));
if (inference.buffer == NULL) {
return false; // Return false if memory allocation fails
// Initialize inference buffer settings
inference.buf_count = 0; // Reset sample count
inference.n_samples = n_samples; // Store number of required samples
inference.buf_ready = 0; // Mark buffer as not ready yet
// Set the callback function that will be triggered when PDM data is available
PDM.onReceive(pdm_data_ready_inference_callback);
// Set the size of the internal PDM buffer
PDM.setBufferSize(2048);
// Give the microphone some time to initialize
delay(250);
// Begin capturing from PDM microphone with 1 channel at classifier frequency
if (!PDM.begin(1, EI_CLASSIFIER_FREQUENCY)) {
ei_printf("ERR: Failed to start PDM!"); // Print error if microphone fails to start
microphone_inference_end(); // Clean up resources
return false; // Return failure
return true; // Microphone successfully started
Defines the microphone_inference_record() function, which waits for the microphone buffer to be filled with audio samples. Once the buffer is ready, it resets the buffer state and prepares for the next recording cycle.
static bool microphone_inference_record(void) {
record_ready = true; // Set the flag indicating that the system is ready to start recording
while (inference.buf_ready == 0) { // Wait until the buffer is full (i.e., ready for processing)
delay(10); // Brief delay to avoid busy-waiting
inference.buf_ready = 0; // Reset the buffer ready flag after processing the data
record_ready = false; // Reset the recording flag, indicating recording is no longer active
return true; // Return true indicating the recording was successful
Defines two functions: microphone_audio_signal_get_data(), which converts raw audio data from the buffer into a float format, and microphone_inference_end(), which cleans up by stopping the PDM and freeing memory allocated for the audio buffer.
// Function to retrieve audio data from the inference buffer and convert it to float format
static int microphone_audio_signal_get_data(size_t offset, size_t length, float *out_ptr) {
numpy::int16_to_float(&inference.buffer[offset], out_ptr, length); // Convert int16 audio data to float format
return 0; // Return 0 to indicate success
// Function to clean up the microphone inference by stopping the PDM and freeing memory
static void microphone_inference_end(void) {
PDM.end(); // Stop the Pulse Density Modulation (PDM) interface
ei_free(inference.buffer); // Free the memory allocated for the inference buffer
Defines the print_inference_result() function, which outputs the results of the inference, including the timing of different stages — DSP, classification, anomaly detection — and the prediction values for each class.
void print_inference_result(ei_impulse_result_t result) {
// Print timing information for the DSP, inference, and anomaly stages
ei_printf("Timing: DSP %d ms, inference %d ms, anomaly %d ms\n",
result.timing.dsp, // Time taken for DSP processing
result.timing.classification, // Time taken for classification
result.timing.anomaly); // Time taken for anomaly detection
ei_printf("Predictions:\n");
// Loop through each class and print the classification result
ei_printf(" %s: %.5f\n", // Print class name and its predicted value
result.classification[i].value);
// If anomaly detection is enabled, print the anomaly prediction
#if EI_CLASSIFIER_HAS_ANOMALY == 1
ei_printf("Anomaly prediction: %.3f\n", result.anomaly); // Print the anomaly score
#endif
The ei_printf command is a custom logging function from the Edge Impulse SDK, used for printing debug or inference-related information to the serial monitor, optimized for embedded systems. It works similarly to printf but is tailored for the Edge Impulse environment. You can find the complete Code_Sample.ino in the example repository and try it out yourself.
Now that you have a good understanding of the code, you should run it on your device. With your Arduino Nano RP2040 plugged into your computer, and the correct board and port selected in the Arduino IDE, follow these steps:
If you’re using the Upload Button:
If you’re using the Sketch Menu:
Your board should now start running the uploaded code automatically.
To confirm that your code is running properly:
These messages indicate that your model is working and processing voice input as expected.
Your Serial Monitor should look like the image below:
Circuit Connection
Congratulations, you’ve successfully programmed your first TinyML microcontroller! You’ve also built a functional, smart system to control an LED with your voice.
