To get started with your first TinyML project, the Arduino Nano RP2040 Connect is a good option. Built by Arduino, it uses the RP2040 microcontroller and is fully supported by the Arduino core package.
The board comes with built-in Wi-Fi, Bluetooth, and an onboard IMU. These are features that are useful for deploying machine learning models at the edge.
Arduino Nano RP2040
Its compatibility with popular tools like Edge Impulse and the Arduino IDE makes it a suitable choice for TinyML applications. You can learn more about the Arduino Nano RP2040 Connect on the Arduino website .
This guide will help you connect the Arduino Nano RP2040 Connect to your computer and set up the Arduino IDE for programming.
To visualize the output of the voice command model, you’ll use a simple LED circuit.
You will need the following components:
To program and deploy your trained model to the Arduino Nano RP2040, you first need to configure your development environment.
Follow the steps in the Arduino Nano RP2040 install guide .
This guide walks you through:
Open the Arduino IDE. To select your board:
Go to Tools > Board then select Arduino Nano RP2040 Connect
To select your port:
Connect your board to your computer using a USB cable, then follow these steps:
COM4 (Arduino Nano RP2040 Connect) or /dev/cu.usbmodem... on macOS.Your Arduino IDE is now ready to upload code to the Arduino Nano RP2040.
