Before cloning the repository, confirm that Git is available:
git --version
Clone the robots repository, which contains the robot runtime and the robot_mesh Strands tool:
mkdir ~/strands-device-connect
cd strands-device-connect
git clone https://github.com/strands-labs/robots
The repository includes a setup.sh script that installs uv, creates a Python 3.12 virtual environment, and installs all required packages:
cd ~/strands-device-connect/robots
./strands_robots/device_connect/setup.sh
source .venv/bin/activate
The strands-robots SDK uses Device Connect’s built-in device-to-device discovery: every Robot() instance announces itself on the local network at startup, and any process running discover_devices() or robot_mesh(action='peers') on the same network segment will find it automatically.
This means discovery works as long as the device process and the agent process are on the same LAN or on the same machine. Discovery is typically available on home and office networks. If you’re behind a firewall or VPN that blocks local network traffic, devices won’t discover each other - that scenario requires the infrastructure-backed setup with a Zenoh router, which is covered later in this Learning Path.
At this point you’ve:
robots repository.The next section walks you through starting a simulated robot and invoking it from both the agent tools and the robot_mesh Strands tool.
