Run MobileSAM prompt segmentation on Arm Ethos-U85 with ExecuTorch
Understand the MobileSAM deployment workflow
Prepare the ExecuTorch and Arm environment
Export MobileSAM for Ethos-U85
Build and run MobileSAM on the Corstone-320 FVP
Validate the MobileSAM segmentation result
Reconstruct the target mask
Run the visualization tool from the ExecuTorch repository root without arguments. It reads the Fixed Virtual Platform (FVP) output tensor from output-0.bin under arm_test/mobilesam/io/ and thresholds its mask logits at zero. It compares the mask with quantized_mask.png under arm_test/mobilesam/export/:
python3 examples/arm/mobilesam_prompt_segmentation_example_ethos_u/runtime/visualize_fvp_output.py
The tool requires 112 × 112 float32 logits and exits with an error if the FVP and host masks have an intersection over union (IoU) below 0.9. The threshold is fixed in the script.
On success, it prints FVP/reference mask IoU: with the measured score and a Saved line with the comparison image path. It writes fvp_mask.png, fvp_comparison.png, and metrics.json under arm_test/mobilesam/result/.
Inspect the metrics
Display the target comparison metrics:
python3 -m json.tool arm_test/mobilesam/result/metrics.json
Confirm that fvp_reference_iou is at least 0.9.
The exporter already checked the floating-point and quantized host masks. Display that result if you want to inspect the earlier stage:
python3 -m json.tool arm_test/mobilesam/export/metrics.json
The fp32_quantized_iou value must also be at least 0.9.
Confirm Ethos-U delegation
Display the delegation report written during export:
sed -n '1,120p' arm_test/mobilesam/export/delegation.txt
Confirm that Total delegated subgraphs is 1. The exporter checks this before writing the .pte. The output includes:
Total delegated subgraphs: 1
Node counts can vary with dependency versions. Use the values from your export when reporting delegation.
In arm_test/mobilesam/fvp.log, also confirm NPU delegations: 1. This count records a completed NPU invocation at runtime; the export report shows how the model was partitioned.
The FVP reports CPU timing and CPU/NPU ratios as N/A. Fast mode also marks NPU PMU counters as unavailable; timing mode reports simulated NPU counters. Use the delegation count and mask comparison to validate execution. Simulated counters are not measurements of real-device latency.
Inspect the visual result
Open fvp_comparison.png under arm_test/mobilesam/result/ in an image viewer. The image contains three panels:
- The resized input image with the positive point prompt
- The host quantized segmentation overlay
- The FVP segmentation overlay
Compare the object boundaries in the two mask overlays. The FVP mask should select the dog at the positive point prompt and closely match the host quantized result.
What you’ve accomplished
You’ve completed the MobileSAM deployment flow from PyTorch export to bare-metal execution on Ethos-U85. You also checked that both the host quantization comparison and the FVP mask comparison meet the 0.9 IoU threshold.
