Run MobileSAM prompt segmentation on Arm Ethos-U85 with ExecuTorch
Understand the MobileSAM deployment workflow
Prepare the ExecuTorch and Arm environment
Export MobileSAM for Ethos-U85
Build and run MobileSAM on the Corstone-320 FVP
Validate the MobileSAM segmentation result
Check your development machine
Use Python 3.12 with development headers and virtual-environment support. On Linux, also install the GLib and OpenMP runtime packages (libglib2.0-0 and libgomp1 on Ubuntu). Run the following preflight check before downloading the source:
case "$(uname -s)/$(uname -m)" in
Linux/x86_64|Linux/aarch64|Linux/arm64|Darwin/arm64)
echo "Supported host: $(uname -s)/$(uname -m)"
echo "Unsupported host: $(uname -s)/$(uname -m)" >&2
exit 1
esac
for tool in python3.12 git c++ ninja curl pkg-config xz; do
command -v "$tool" >/dev/null || {
echo "Missing required tool: $tool" >&2
exit 1
done
python3.12 - <<'PY' || exit 1
import platform
import sys
if sys.platform == "darwin":
version = platform.mac_ver()[0]
if not version or int(version.split(".")[0]) < 15:
raise SystemExit(f"macOS 15 or later is required; found {version or 'unknown'}.")
elif sys.platform.startswith("linux"):
libc, version = platform.libc_ver()
if libc != "glibc" or tuple(map(int, version.split(".")[:2])) < (2, 28):
raise SystemExit(
f"Linux with glibc 2.28 or later is required; found {libc} {version}."
PY
python3.12 --version
git --version
c++ --version | head -n 1
The check confirms that you are using a supported Linux host or Apple silicon Mac. It also checks for the availability of the following:
- Python 3.12
- Git
- A host C++ compiler
- Ninja
- curl, pkg-config, and xz
The Python export dependencies require macOS 15 or later on Apple silicon, or glibc 2.28 or later on Linux. The pinned TOSA tools set the macOS minimum, and the PyTorch wheels require the Linux glibc version. The preflight check verifies these requirements before you install the dependencies.
On Linux, the Corstone-320 FVP also requires libstdc++.so.6 providing GLIBCXX_3.4.26 or later.
Clone the ExecuTorch source
Clone ExecuTorch, select the revision used by this Learning Path, and initialize its submodules:
git clone https://github.com/pytorch/executorch.git
cd executorch
git fetch origin fe93a8b0fc8d363fbb3bfa2aa18e253507fd13f8
git checkout fe93a8b0fc8d363fbb3bfa2aa18e253507fd13f8
git submodule sync
git submodule update --init --recursive
Run the remaining commands from the ExecuTorch repository root. The pinned revision keeps the commands aligned with the MobileSAM example source .
Create a Python environment
Create and activate a fresh Python 3.12 virtual environment for this checkout:
python3.12 -m venv .venv
source .venv/bin/activate
Install ExecuTorch
Build the Python package from the same checkout used by the example and native runner:
CMAKE_GENERATOR=Ninja ./install_executorch.sh --optional-dependency ethos_u
The installer supplies CMake, the model export dependencies, and the example requirements. It selects released PyTorch and TorchAO packages for the CPU workflow.
Install the Arm development tools
Before you run the Arm setup command on macOS, install
Docker Desktop
and start Docker. Install the
FVPs-on-Mac wrappers
at the revision for FVP 11.31.28. The wrapper runs the Linux Corstone-320 FVP in a container. Run these commands from the ExecuTorch repository root:
docker info >/dev/null
mkdir -p examples/arm/arm-scratch "$HOME/.armlm"
git clone https://github.com/Arm-Examples/FVPs-on-Mac.git \
examples/arm/arm-scratch/FVPs-on-Mac
git -C examples/arm/arm-scratch/FVPs-on-Mac checkout --detach \
cc7a4be5456db085619647811fac29e9795f806e
bash examples/arm/arm-scratch/FVPs-on-Mac/build.sh
export PATH="$PWD/examples/arm/arm-scratch/FVPs-on-Mac/bin:$PATH"
export FVP_MOUNT_DIR="$PWD"
FVP_Corstone_SSE-320 --version
command -v FVP_Corstone_SSE-320
The Arm setup script installs the pinned GNU bare-metal toolchain, Ethos-U Vela compiler, and Corstone FVP used by the example. Read the End User License Agreements presented by the tooling before you accept them, then run:
./examples/arm/setup.sh --i-agree-to-the-contained-eula
source examples/arm/arm-scratch/setup_path.sh
Verify the environment
Check that the Python dependencies are consistent after Arm setup:
python -m pip check
Confirm that the output is No broken requirements found.
Check the ExecuTorch and Ethos-U imports used by the exporter:
python - <<'PYTHON'
import executorch.kernels.quantized
from executorch.backends.arm.ethosu import EthosUPartitioner
from executorch.backends.arm.quantizer import EthosUQuantizer
print("ExecuTorch Ethos-U imports succeeded")
PYTHON
The output is similar to:
Check the target compiler and FVP:
arm-none-eabi-gcc -dumpmachine
The output of the first command is similar to:
arm-none-eabi
The second command prints the path to the Corstone-320 FVP. On macOS, confirm that this path is inside the FVPs-on-Mac bin directory.
Choose how to run the example
To run preparation, export, build, FVP execution, and validation together, use the example’s script without arguments:
./examples/arm/mobilesam_prompt_segmentation_example_ethos_u/run.sh
The expected output at the end of a successful run is:
MobileSAM example: PASS
The comparison image, fvp_comparison.png, is saved under arm_test/mobilesam/result/. After the script completes, continue to
to inspect the artifacts.
To run the same workflow with simulated NPU counters, use timing mode:
./examples/arm/mobilesam_prompt_segmentation_example_ethos_u/run.sh --timed
Timing mode uses a 7,200-second timeout; the default fast mode uses 300 seconds. CPU timing and CPU/NPU ratios remain unavailable on FVP.
To work through each stage manually, skip this script and continue to the next page. The following pages explain the same preparation, export, build, and validation steps. Continue only after each command succeeds; files from an earlier run can remain after a failed command.
You’ve installed the Python, compiler, Vela, and virtual-platform dependencies used by the example.
Next, you’ll prepare and export MobileSAM for Ethos-U85.
