Run MobileSAM prompt segmentation on Arm Ethos-U85 with ExecuTorch
Understand the MobileSAM deployment workflow
Prepare the ExecuTorch and Arm environment
Export MobileSAM for Ethos-U85
Build and run MobileSAM on the Corstone-320 FVP
Validate the MobileSAM segmentation result
Prepare the MobileSAM source and checkpoint
Run all commands from the ExecuTorch repository root. Confirm that your Python environment is active and that you’ve sourced the Arm tools’ setup_path.sh file in the current shell, as shown during environment setup.
Prepare the pinned MobileSAM source and checkpoint:
python3 examples/arm/mobilesam_prompt_segmentation_example_ethos_u/model_export/prepare_mobilesam.py
The script downloads the
pinned MobileSAM revision
, applies the patch needed for a configurable image size, and verifies the checkpoint’s SHA-256 checksum. It stores the source in source/ and the checkpoint in mobile_sam.pt, outside the ExecuTorch repository. The cache directory is:
~/.cache/executorch/mobilesam/f706ad9c4eb7f219c00d9050e46328518ffb65d2/
Export the ExecuTorch program
Export the example image and positive point prompt for the ethos-u85-256 target:
python3 examples/arm/mobilesam_prompt_segmentation_example_ethos_u/model_export/export_mobilesam.py
The exporter loads the prepared checkpoint, calibrates post-training quantization with the example image, checks the quantized mask against the floating-point mask, and lowers the graph to Ethos-U85.
This script uses one fixed configuration: examples/models/dinov2/dog.jpg, positive point (219, 193), input size 448, target ethos-u85-256, and memory mode Dedicated_Sram_384KB. These values are set in the Python source rather than through command-line arguments.
Export requires a host mask intersection over union (IoU) of at least 0.9 and exactly one Ethos-U delegated subgraph. It writes mobilesam.pte to arm_test/mobilesam/export/.
Verify the export artifacts
The files under arm_test/mobilesam/export/ support the remaining steps:
| Artifact | Path |
| ExecuTorch program | mobilesam.pte |
| Preprocessed float32 input tensor | input.bin |
| Resized and padded input image | input.png |
| Floating-point host mask | fp32_mask.png |
| Quantized host mask | quantized_mask.png |
| Host mask metrics | metrics.json |
| Delegation report | delegation.txt |
| TOSA and Vela artifacts | artifacts/ |
Check that these artifacts exist before building the runner:
export_dir=arm_test/mobilesam/export
for artifact in \
mobilesam.pte \
input.bin \
input.png \
fp32_mask.png \
quantized_mask.png \
metrics.json \
delegation.txt; do
test -s "$export_dir/$artifact" || {
echo "Missing export artifact: $export_dir/$artifact" >&2
exit 1
done
test -n "$(find "$export_dir/artifacts" -type f -print -quit)" || {
echo "No TOSA or Vela artifacts found in $export_dir/artifacts" >&2
exit 1
The checks complete without output when the artifacts are present. The point prompt is embedded in the .pte, which is compiled into the runner. The image remains a runtime input: the runner reads input.bin through semihosting, which lets the FVP access files on the host.
You’ve prepared MobileSAM and exported a quantized ExecuTorch program for Ethos-U85.
Next, you’ll build the bare-metal application and run it on the Corstone-320 FVP.
