# Understand the toolchains used in the Topo Project
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/deploy-ml-model-to-npu-with-topo/)
- [Understand the architecture of the machine learning application](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/deploy-ml-model-to-npu-with-topo/overview/)
- [Understand the toolchains used in the Topo Project](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/deploy-ml-model-to-npu-with-topo/what-are-the-toolchains/)
- [Build the Topo Project from scratch](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/deploy-ml-model-to-npu-with-topo/build-the-project/)
- [Clone and deploy the application with Topo](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/deploy-ml-model-to-npu-with-topo/deploy/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/deploy-ml-model-to-npu-with-topo/_next-steps/)
## Understand the build and runtime components
The `topo-imx93-npu-deployment` Topo Project combines several toolchains. Topo hides much of the deployment plumbing, but it’s useful to understand what’s being built and where each component runs.
### ExecuTorch
ExecuTorch is PyTorch’s runtime for deploying PyTorch models to edge devices. By using different backends within ExecuTorch, you can target specific hardware. For example, you can target Ethos-U65 by using the Ethos-U backend.
To learn more about how the MobileNetV2 model was exported from PyTorch to ExecuTorch and delegated to the Ethos-U, see [Build ExecuTorch models for Ethos-U65](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/observing-ethos-u-on-nxp/7-build-executorch-pte/).
In this Topo Project, ExecuTorch is used in two places:
- At build time, the project exports a MobileNetV2 model to an ExecuTorch `.pte` program.
- At run time, the Cortex-M33 firmware loads and executes that `.pte` program.
- [ExecuTorch](https://docs.pytorch.org/executorch/stable/index.html)
The export pipeline targets `ethos-u65-256`, which means the Ethos-U65 has 256 multiply-accumulate (MAC) units. The model is quantized and lowered so supported neural network operators can be delegated to the Ethos-U65 NPU.
The generated file is `mv2_ethosu65_256.pte`.
The web application includes this `.pte` file in its container image. During inference, it writes the file into the reserved physical memory range starting at `0xC0000000`, where the Cortex-M33 runner can read it.
### Cortex-M33 firmware runner
The firmware runner is built as `executorch_runner_cm33.elf`.
This firmware runs on the Cortex-M33 core. It waits for commands coming from the Linux web application over `RPMsg`, reads input image tensors from reserved memory, runs inference through ExecuTorch, and writes classification output back over `RPMsg`.
The Topo Project packages the firmware as the entrypoint of the `cm33-runner` image:
```yaml
cm33-runner:
  runtime: io.containerd.remoteproc.v1
  annotations:
    remoteproc.name: imx-rproc
The `runtime: io.containerd.remoteproc.v1` setting tells containerd to use the remote processor runtime instead of the normal Linux container runtime. The `remoteproc.name` annotation identifies the target remote processor driver, `imx-rproc`.
### remoteproc-runtime
Linux includes a `remoteproc` framework for loading and controlling auxiliary processors such as the Cortex-M33 on the i.MX 93. `remoteproc-runtime` adds an Open Container Initiative (OCI) interface on top of this framework, allowing firmware to be packaged and launched using container tooling.
Topo uses `remoteproc-runtime` when deploying the `cm33-runner` service. The deployment flow is:
1. Topo builds the `runner-runtime` image containing `executorch_runner_cm33.elf`.
2. Topo starts the image on the target.
3. containerd uses `io.containerd.remoteproc.v1`.
4. `remoteproc-runtime` passes the ELF file to the Linux `remoteproc` driver.
5. The kernel loads the ELF segments and releases the Cortex-M33.
The target must pass the `Remoteproc Runtime`, `Remoteproc Shim`, and `Subsystem Driver (remoteproc)` checks in `topo health`.
### RPMsg
`RPMsg` is the communication channel between the Cortex-A Linux application and the Cortex-M33 firmware. The web application sends a `RUN` command over a `/dev/ttyRPMSG*` device. The firmware replies with status and classification output.
If the deployment succeeds but classification times out, inspect the web app’s board checks and the target’s `RPMsg` devices. The application expects an `RPMsg` TTY to appear after the Cortex-M33 firmware starts.
### Shared reserved memory
The web application and firmware exchange model and input data through reserved physical memory. The Topo Project expects the target device tree to reserve:
- `model@c0000000`: 4 MiB for the ExecuTorch `.pte` file and input tensor.
- `ethosu_region@A8000000`: 128 MiB for Ethos-U65 use.
The web application checks these ranges at startup through `/proc/device-tree`. It also checks for `/dev/mem`, `/dev/ethosu0`, the `imx-rproc` remote processor, the `.pte` file, and ImageNet labels.
### Web application
The `webapp` service is a Python Flask application. The application serves the browser UI and preprocesses selected images. It stages the `.pte` program and input tensor in reserved memory, sends inference commands over `RPMsg`, and renders the ImageNet top-1 and top-5 results.
By default, the service publishes port `3001` on the target and forwards it to container port `3000`.
## What you’ve learned and what’s next
You now understand the major toolchains and runtime interfaces used by the Topo Project: ExecuTorch, the Cortex-M33 firmware runner, remoteproc-runtime, RPMsg, reserved memory, and the Flask web application. You’ve also seen how the web application stages the `.pte` program and input data in reserved memory before sending inference commands to the Cortex-M33 firmware.
Next, you’ll build the Topo Project from the base projects by adding the Compose services, build artifacts, Remoteproc Runtime metadata, and Topo parameters.
