# Build the Topo Project from scratch
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/deploy-ml-model-to-npu-with-topo/)
- [Understand the architecture of the machine learning application](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/deploy-ml-model-to-npu-with-topo/overview/)
- [Understand the toolchains used in the Topo Project](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/deploy-ml-model-to-npu-with-topo/what-are-the-toolchains/)
- [Build the Topo Project from scratch](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/deploy-ml-model-to-npu-with-topo/build-the-project/)
- [Clone and deploy the application with Topo](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/deploy-ml-model-to-npu-with-topo/deploy/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/deploy-ml-model-to-npu-with-topo/_next-steps/)
## What you will build
In this section, you’ll build the `topo-imx93-npu-deployment` Topo Project starting from two non-Topo, non-Compose projects:
- a Cortex-A web application that prepares images, writes model and tensor data into shared memory, and sends inference commands over `RPMsg`
- a Cortex-M33 ExecuTorch runner firmware project for the FRDM i.MX 93
You’ll combine those sources into one repository, then make the repository a normal Compose project. Then, you’ll add the Topo metadata and Remoteproc Runtime services.
## Create the repository from the base projects
Start by copying the original base projects from the Topo Project.
Clone the Topo repository for the Topo Project specification and validation schema, clone the original Topo Project for the source files, and start a new empty repository:
git clone [https://github.com/arm/topo.git](https://github.com/arm/topo.git)
git clone [https://github.com/Arm-Examples/topo-imx93-npu-deployment.git](https://github.com/Arm-Examples/topo-imx93-npu-deployment.git)
mkdir new-topo-npu-template
cd new-topo-npu-template
Create the project layout:
mkdir -p webapp executorch-runner licenses
Copy the relevant `webapp` files:
cp -R ../topo-imx93-npu-deployment/webapp/src webapp
Copy the Cortex-M33 runner build inputs from the firmware project:
cp ../topo-imx93-npu-deployment/executorch-runner/build-runner.sh executorch-runner/build-runner.sh
cp ../topo-imx93-npu-deployment/executorch-runner/export_mv2_imx93.py executorch-runner/export_mv2_imx93.py
cp ../topo-imx93-npu-deployment/executorch-runner/docker-entrypoint.sh executorch-runner/docker-entrypoint.sh
cp -R ../topo-imx93-npu-deployment/executorch-runner/patches executorch-runner
Add the licenses and ignore rules used by the source projects:
cp ../topo-imx93-npu-deployment/LICENSE.md .
cp -R ../topo-imx93-npu-deployment/licenses .
cp ../topo-imx93-npu-deployment/.gitignore .
You have two sets of source code combined into one repository. It’s not a Compose project and it’s not a Topo Project.
You’ll now create a Compose project and Topo Project around the source code.
The Compose project provides the container build and runtime structure. A Dockerfile describes how to build one image. A Compose file describes the services that use those images, their build contexts, ports, volumes, dependencies, and runtime settings. In this Topo Project:
- `webapp/Dockerfile` builds the Flask image.
- `webapp/compose.yaml` keeps the web app’s build context and Linux runtime settings close to the web app source.
- `executorch-runner/Dockerfile` builds the ExecuTorch `.pte` model and Cortex-M33 runner ELF through multi-stage Docker builds.
- the root `compose.yaml` is the Topo Project entry point. It combines the web app, artifact build services, the Remoteproc Runtime service, and the root-level `x-topo` metadata.
For a general introduction to Compose projects, services, and the `compose.yaml` file, see Docker’s [How Compose works](https://docs.docker.com/compose/intro/compose-application-model/) documentation.
**Note**: When you creating a file for any of the following steps, paste the complete file contents as shown.
When you update part of an existing Compose file for a step, merge the YAML into the existing top-level key shown by the snippet. For example, if a snippet starts with `services:`, add the named service under the existing top-level `services:` map. Don’t create a second `services:` block in the same file.
## Turn the sources into a Compose project
Before adding Topo metadata, make the project work as ordinary Compose. Start by containerizing the Cortex-A web application.
Create `webapp/Dockerfile` with the following complete contents:
FROM python:3.12-slim
WORKDIR /app
ENV PYTHONUNBUFFERED=1
RUN python -m pip install --no-cache-dir flask==3.0.3
COPY src/data/imagenet_classes.txt /opt/mv2-imx93/imagenet_classes.txt
COPY src/app.py .
COPY src/templates/ templates/
COPY src/static/ static/
EXPOSE 3000
CMD ["python", "app.py"]
Create `webapp/compose.yaml` with the following complete contents:
services:
  webapp:
    platform: linux/arm64
    build:
      context: .
      dockerfile: Dockerfile
    privileged: true
    ports:
      - "${WEBAPP_PORT:-3001}:3000"
    volumes:
      - /sys:/sys
      - /dev:/dev
    restart: unless-stopped
Create the root `compose.yaml` with the following complete contents:
services:
  webapp:
    extends:
      file: webapp/compose.yaml
      service: webapp
Check that Compose can read the project:
docker compose config
The output includes the resolved `webapp` service, and is similar to:
__output__
services:
__output__
webapp:
__output__
  build:
__output__
    context: /path/to/new-topo-npu-template/webapp
__output__
  ports:
__output__
    - mode: ingress
      target: 3000
      published: "3001"
At this point, Compose can build and run the Cortex-A web application as a normal Linux container. The image runs `webapp/src/app.py`. It packages the Jinja templates from `webapp/src/templates/`, the static assets from `webapp/src/static/`, and the ImageNet labels from `webapp/src/data/imagenet_classes.txt`. The container listens on port `3000`, and Compose publishes it on host port `3001` unless you set `WEBAPP_PORT` to another value.
## Add the ExecuTorch artifact pipeline
The web application needs an ExecuTorch `.pte` model, and the target needs a Cortex-M33 ELF image. Both artifacts are built by `executorch-runner/Dockerfile`.
Copy the Dockerfile into the runner build context:
cp ../topo-imx93-npu-deployment/executorch-runner/Dockerfile executorch-runner/
For this multi-stage Dockerfile:
- `build-base`: installs the common Ubuntu build tools.
- `executorch-base`: clones ExecuTorch, installs the Arm backend dependencies, and copies `export_mv2_imx93.py` and `docker-entrypoint.sh`.
- `pte-builder`: exports `mv2_ethosu65_256.pte`.
- `pte-artifacts`: packages the `.pte` file as a BuildKit artifact context.
- `runner-base`: installs the Arm GNU toolchain, MCUX SDK, RPMsg-Lite dependencies, runner sources, and local patches.
- `runner-builder`: builds `executorch_runner_cm33.elf`.
- `runner-artifacts`: packages the ELF for inspection or reuse.
- `runner-runtime`: produces a `scratch` image whose entrypoint is the ELF file.
The important artifact stages look like this:
FROM busybox:1.36 AS pte-artifacts
COPY --from=pte-builder /workspace/build/mv2-imx93/mv2_ethosu65_256.pte /artifacts/mv2_ethosu65_256.pte
FROM busybox:1.36 AS runner-artifacts
COPY --from=runner-builder /artifacts/executorch_runner_cm33.elf /artifacts/executorch_runner_cm33.elf
FROM scratch AS runner-runtime
COPY --from=runner-builder /artifacts/executorch_runner_cm33.elf /executorch_runner_cm33.elf
ENTRYPOINT ["/executorch_runner_cm33.elf"]
## Connect the artifact services
Add `pte-artifacts` and `runner-artifacts` as siblings of the existing `webapp` service in the root `compose.yaml`:
services:
  pte-artifacts:
    scale: 0
    build:
      context: executorch-runner
      target: pte-artifacts
      cache_from:
        - ${EXECUTORCH_BASE_CACHE_IMAGE:-ghcr.io/arm-examples/topo-imx93-npu-deployment/executorch-base:et-v1.2.0-ubuntu24.04}
  runner-artifacts:
    scale: 0
    build:
      target: runner-artifacts
      cache_from:
        - ${IMX93_RUNNER_BUILD_CACHE_IMAGE:-ghcr.io/arm-examples/topo-imx93-npu-deployment/imx93-runner-build:mcux-v25.09.00-armgcc14.2-ubuntu24.04}
Don’t replace the existing root `webapp` service with this snippet. The root file should now have three service names under the same top-level `services:` map: `webapp`, `pte-artifacts`, and `runner-artifacts`.
These services are used only to build artifacts. They don’t run as part of the deployed application. `scale: 0` tells Compose not to start containers for them, while still allowing other services to copy files from their build outputs.
Replace `webapp/compose.yaml` with the following version so the Flask image imports the `.pte` artifact:
services:
  webapp:
    build:
      context: .
      additional_contexts:
        pte_artifacts: service:pte-artifacts
    privileged: true
    ports:
    volumes:
      - /sys:/sys
      - /dev:/dev
Then add the `.pte` copy line to `webapp/Dockerfile` with the other `COPY` commands:
COPY --from=pte_artifacts /artifacts/mv2_ethosu65_256.pte /opt/mv2-imx93/mv2_ethosu65_256.pte
The `/opt/mv2-imx93/` path is the location the Flask application expects for its MobileNetV2 support files. At run time, the app reads the `.pte` file from this path before copying it into reserved memory for the Cortex-M33 runner.
## Add the Remoteproc Runtime service
Add the Cortex-M33 runner as another sibling under the top-level `services:` map in the root `compose.yaml`:
services:
  cm33-runner:
    build:
      target: runner-runtime
      cache_from:
    runtime: io.containerd.remoteproc.v1
    annotations:
      remoteproc.name: imx-rproc
Keep the existing `webapp`, `pte-artifacts`, and `runner-artifacts` services in the same file. This step adds one more service and doesn’t replace any of the previous services.
This is the heterogeneous deployment hook. Docker still builds an image, but the service doesn’t start as a Linux userspace process. The runtime `io.containerd.remoteproc.v1` selects Remoteproc Runtime, and the `remoteproc.name` annotation tells the shim to use the i.MX remote processor driver.
Update the existing root `webapp` service so it depends on the CM33 runner and passes the cache image values into the build. Keep the existing `extends` block, then add `depends_on` and `build.args` as shown:
services:
  webapp:
    extends:
      service: webapp
    depends_on:
      - cm33-runner
    build:
      args:
        EXECUTORCH_BASE_CACHE_IMAGE: ghcr.io/arm-examples/topo-imx93-npu-deployment/executorch-base:et-v1.2.0-ubuntu24.04
        IMX93_RUNNER_BUILD_CACHE_IMAGE: ghcr.io/arm-examples/topo-imx93-npu-deployment/imx93-runner-build:mcux-v25.09.00-armgcc14.2-ubuntu24.04
The web app is privileged and mounts `/sys` and `/dev` because it checks the device tree, reads remoteproc state through `/sys/class/remoteproc`, talks to `/dev/ttyRPMSG*`, writes shared memory through `/dev/mem`, and checks for `/dev/ethosu0`.
Keep the web app build context in `webapp/compose.yaml`. The root `webapp.build.args` block supplies only Topo-collected build arguments. It shouldn’t replace the extended build context and Dockerfile from `webapp/compose.yaml`.
## Add Topo metadata and arguments
After the Compose services are complete, add the root-level `x-topo` block. Keep it at the root of `compose.yaml`, as a sibling of `services`, not under `services`.
If you want to use an agent skill to perform this step, skip to the optional step.
x-topo:
  name: "i.MX93 ExecuTorch runner"
  description: "Runs a Cortex-A web application that sends image inference commands to a resident CM33 ExecuTorch runner over RPMsg."
  features:
    - "remoteproc-runtime"
  parameters:
      description: Optional GHCR image used as a BuildKit cache source for the ExecuTorch PTE build.
      required: false
      default: ghcr.io/arm-examples/topo-imx93-npu-deployment/executorch-base:et-v1.2.0-ubuntu24.04
      description: Optional GHCR image used as a BuildKit cache source for the CM33 runner build.
      required: false
      default: ghcr.io/arm-examples/topo-imx93-npu-deployment/imx93-runner-build:mcux-v25.09.00-armgcc14.2-ubuntu24.04
The `features` value tells Topo that this project requires `remoteproc-runtime` support on the target. This is useful when checking for project compatibility with the `topo projects --target <target>` command.
The `parameters` entries describe configurable build inputs. Compose consumes those values through the `cache_from` interpolation that you added earlier:
cache_from:
The root `webapp.build.args` block also makes the Topo-provided values visible in the Compose build model while preserving the `webapp/` build context inherited through `extends`.
Keep runtime settings such as `WEBAPP_PORT` as normal Compose interpolation unless you intentionally want Topo to collect them as Topo Project setup arguments.
## (Optional) Use an Agent Skill to add the Topo metadata
[Topo](https://github.com/arm/topo) currently provides the following skills:
- `topo-project-context`: provides Topo and Topo Project reference context for questions about x-topo metadata, schema, docs, and CLI project behavior.
- `topo-project-bootstrap`: converts a repository into a Topo Project by adding or improving `compose.yaml` and `x-topo` metadata.
- `topo-project-lint`: reviews an existing Topo Project for correctness, consistency, and authoring best practices.
- `topo-project-optimize-deployment`: optimizes feedback loop by measuring and applying the highest-leverage Docker build improvement.
Install the skills with:
npx skills add arm/topo
If your agent doesn’t use `npx skills`, manually copy or symlink the skill directories from Topo into your agent’s skills directory.
Restart your agent after installing or updating the skills.
From the root of the Compose project, ask your agent to use `topo-project-bootstrap`:
Use topo-project-bootstrap on this repository.
Treat the root compose.yaml as the project root.
Preserve plain docker compose behavior.
Add x-topo metadata only where it reflects the actual services, hardware requirements, and build arguments.
After bootstrap, ask the agent to use `topo-project-lint`:
Use topo-project-lint on this repository.
Validate compose.yaml against the Topo Project specification schema.
Check README alignment, Remoteproc Runtime metadata, and x-topo.parameters wiring.
## Validate the final Topo Project
Check the Compose model and check that the Topo metadata is present:
In the `docker compose config` output, check that the resolved `webapp` service has:
- `build.context` ending in `/webapp`
- `build.dockerfile` set to `Dockerfile`
- `build.additional_contexts.pte_artifacts` set to `service:pte-artifacts`
Install `check-jsonschema` if it’s not already available:
brew install check-jsonschema
sudo apt update
sudo apt install -y pipx
pipx ensurepath
pipx install check-jsonschema
export PATH="$HOME/.local/bin:$PATH"
Validate the root Compose file with the schema in the Topo Project specification:
check-jsonschema \
  --schemafile ../topo/docs/project-specification/schema/topo-project-specification.json \
  compose.yaml
Review these points:
- `compose.yaml` contains root-level `x-topo` metadata.
- `x-topo.features` includes `remoteproc-runtime`.
- non-remoteproc services set `platform: linux/arm64`.
- `pte-artifacts` and `runner-artifacts` use `scale: 0`.
- `cm33-runner` uses `runtime: io.containerd.remoteproc.v1`.
- `cm33-runner` has `remoteproc.name: imx-rproc`.
- `webapp` depends on `cm33-runner`.
- `webapp` imports the `.pte` file through `additional_contexts`.
- every `x-topo.parameters` entry is consumed by Compose interpolation.
## What you’ve accomplished and what’s next
You started with two non-Topo, non-Compose projects, made them a standard Compose project, and then converted that Compose project into a Topo Project. You created the web app image, added artifact builds for the ExecuTorch `.pte` model and Cortex-M33 ELF, packaged the firmware as a Remoteproc Runtime service, and exposed the build cache inputs as Topo parameters.
Next, you’ll prepare the FRDM i.MX 93 target, deploy the project with Topo, and run the image classification application.
