Explore related resources
Give feedback
AI-assisted
Close
How do I confirm the FRDM i.MX 93 target is ready before deploying?
Run topo health --target <user>@<target-ip>. The host and target sections should show successful checks for SSH and the container engine, and the target should also report Remoteproc Runtime and Remoteproc as healthy.
Which components run on Cortex-A and Cortex-M33, and how do they communicate?
The Cortex-A side runs the web application that prepares images, writes model and tensor data into shared memory, and sends inference commands. The Cortex-M33 runs the ExecuTorch firmware and receives commands over RPMsg.
What should I expect after deploying the Topo Project?
Topo builds images on the host, transfers them to the target, and starts services on the board. Remoteproc Runtime starts the Cortex-M firmware, and the browser-based MobileNetV2 classifier becomes available.
What are the key steps to turn the two base projects into a Topo Project?
Combine the Cortex-A web app and the Cortex-M33 ExecuTorch firmware sources into a single repository, make it a normal Compose project, then add Topo metadata and Remoteproc Runtime services. The Topo Project is bootstrapped from Compose services, Remoteproc Runtime metadata, and Topo parameters.
What should I check if `topo health` reports a failure?
Resolve the specific errors shown by topo health before continuing. Confirm SSH access to the target, verify the container engine is available on both host and target, and ensure Remoteproc Runtime is present on the target.
Return to Embedded and Microcontrollers
