To follow this Learning Path, you’ll need to install a few additional Python packages alongside CMSIS-DSP.
Start by installing the packages in a Python virtual environment. For example, you can use:
python -m venv cmsis-dsp-venv
If required, activate the environment.
Now install the required packages, starting with CMSIS-DSP:
pip install cmsisdsp
This will also install NumPy, which is a dependency of the CMSIS-DSP Python package.
You’ll be working with a Jupyter notebook, so install the jupyter package:
pip install jupyter
Finally, you’ll also need packages for reading sound files, playing sound using widgets, and displaying plots:
pip install soundfile ipywidgets matplotlib
You can now launch the Jupyter notebook with the following command:
jupyter notebook
A browser window should open, displaying the source tree.
Create a new Jupyter notebook by clicking New and selecting Python 3 (ipykernel). The new notebook is called Untitled. Rename it to something descriptive, for example cmsis-dsp.
Now import all the required packages by copying and running the following Python code into your notebook and run the cell (Shift+Enter).
All the Python code blocks in this Learning Path are intended to be executed in the same Jupyter notebook.
import cmsisdsp as dsp
import cmsisdsp.fixedpoint as fix
from cmsisdsp import datatype as dt
import numpy as np
from numpy.lib.stride_tricks import sliding_window_view
# Package for plotting
import matplotlib.pyplot as plt
# Package to display audio widgets in the notebook and upload sound files
import ipywidgets
from IPython.display import display,Audio
# To convert a sound file to a NumPy array
import io
import soundfile as sf
# To load test patterns from the Arm Virtual Hardware Echo Canceller demo
from urllib.request import urlopen
You’re now ready to move on and set up the audio files you’ll use for processing.
