# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsisdsp-dev-with-python/)
- [CMSIS-DSP Python package](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsisdsp-dev-with-python/how-to-1/)
- [Set up environment](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsisdsp-dev-with-python/how-to-2/)
- [Load an audio file](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsisdsp-dev-with-python/how-to-3/)
- [Write a simple VAD](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsisdsp-dev-with-python/how-to-4/)
- [Write a noise suppression algorithm](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsisdsp-dev-with-python/how-to-5/)
- [Write the CMSIS-DSP Q15 implementation](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsisdsp-dev-with-python/how-to-6/)
- [Convert the CMSIS-DSP Python to C](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsisdsp-dev-with-python/how-to-7/)
- [Develop your knowledge](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsisdsp-dev-with-python/how-to-8/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsisdsp-dev-with-python/_next-steps/)
## Explore related resources
- [Biquad Filters with CMSIS-DSP Python Package](https://developer.arm.com/documentation/102463/latest/)
- [CMSIS-DSP Library (GitHub)](https://github.com/ARM-software/CMSIS-DSP)
- [CMSIS-DSP Python Package (PyPi)](https://pypi.org/project/cmsisdsp/)
- [CMSIS-DSP Python Package Examples and Tests](https://github.com/ARM-software/CMSIS-DSP/tree/main/PythonWrapper/examples)
- [CMSIS-Stream](https://github.com/ARM-software/CMSIS-Stream)
## Review frequently asked questions
### How do I know the CMSIS-DSP Python package installed correctly?
In your activated environment, start Python and import `cmsisdsp` as `dsp` and `numpy`. Call `dsp.arm_hanning_f32` on a small window length and confirm it returns an array without errors.
### I ran the cell that creates the audio widget but nothing appears — what should I check?
Confirm the notebook kernel is running and that the Audio object is the last expression in the cell so Jupyter displays it. Rerun the cells that define filedata and the Audio widget, then check the cell output.
### How should I choose the VAD energy threshold?
Start with a moderate value, then iterate by listening to the result. Aim to remove noise between words without clipping spoken segments. Adjust the threshold and rerun until the segmentation matches what you expect.
### How do I verify that overlapping windows and the Hanning window are applied correctly?
Plot the Hanning window as shown and check that it tapers near zero at both ends. Inspect frame indices to confirm overlap and listen for smooth transitions without clicks at frame boundaries.
### What result should I expect after running the noise suppression steps?
Playback should have reduced background noise during pauses while keeping the “yes” and “no” utterances clear. If speech sounds distorted or noise persists, revisit the VAD threshold and window length.
