# Next Steps
## In this learning path
- [Introduction](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsis_rtx_vs/)
- [Create csolution project](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsis_rtx_vs/create/)
- [Initialize the Operating System](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsis_rtx_vs/initialize/)
- [Create RTOS Threads](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsis_rtx_vs/threads/)
- [Build and run the application](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsis_rtx_vs/build_and_run/)
- [Next Steps](https://learn.arm.com/learning-paths/embedded-and-microcontrollers/cmsis_rtx_vs/_next-steps/)
## Explore related resources
- [CMSIS-RTOS2 Documentation](https://www.keil.com/pack/doc/CMSIS/RTOS2/html/index.html)
- [Event Recorder and Component Viewer](https://www.keil.com/pack/doc/compiler/EventRecorder/html/index.html)
## Review frequently asked questions
### Which target should I use if I don’t have hardware available?
Use the Cortex-M4 Fixed Virtual Platform (FVP) referenced in the steps. The procedure also applies to other devices supported by CMSIS-Pack.
### How do I start a debug session in Keil Studio for VS Code?
Select the **Debug** icon or open the **Run and Debug** view, then choose the configured debug connection to launch the FVP. Use the standard debugging controls to step through your code.
### How do I know the RTOS is running correctly?
After initialization, the **Debug Console** displays messages from your threads. Look for output similar to: `"[model] hello from thread 1/2/3"`.
### Where do main.c and app_main.c come from?
`main.c` is created automatically in the Source Files group when you set up the CMSIS Solution project. Add `app_main.c` by clicking the **+** icon in the Source Files group.
### Can I change the number or names of the threads?
Yes. The number and naming of threads created by `app_main` are flexible, so adjust them to match your application structure.
