Display the manifest report
Now that you’ve created a signed copy of the sample image, you can inspect the credentials of the copy.
Inspect the signed image to see the recorded provenance and the reported signature, content-binding, and signer-trust results.
Run the Coalition for Content Provenance and Authenticity (C2PA) Tool to display its JSON manifest report:
C2PA Tool validates the manifest while reading it. The tool includes those results in the report alongside the recorded provenance fields.
To save the report as a JSON file, redirect the output:
c2patool image-signed.jpg > report.json
This writes the report to report.json in your working directory, replacing that file if it already exists. You can open the file in a text editor if necessary. The signed image remains unchanged.
Find the active manifest
Find active_manifest, locate the same label under manifests, and inspect claim_generator_info:
        "claim_generator_info": [
    "name": "Arm Learning Path C2PA Example",
    "version": "1.0.0",
    "com.arm.learning_path.tool": {
      "name": "c2patool",
      "version": "0.27.21"
    "org.contentauth.c2pa_rs": "0.90.21"
The name and 1.0.0 example version match the values that you supplied in manifest.json. The custom com.arm.learning_path.tool field records the separate tool name and version that you supplied.
C2PA Tool adds org.contentauth.c2pa_rs to identify its underlying library. 0.90.21 is the library version in the tested tool.
Manifest labels, instance IDs, and UUIDs differ between runs.
Inspect the assertions
The assertions array contains a c2pa.actions.v2 assertion:
        "actions": [
    "action": "c2pa.created",
    "digitalSourceType": "http://cv.iptc.org/newscodes/digitalsourcetype/digitalCapture"
This is a declaration supplied by the claim generator. It’s not independent proof of how the depicted scene was produced or whether the scene is truthful.
Inspect the hard binding
Under validation_results, activeManifest, and success, find:
  "code": "assertion.dataHash.match",
  "explanation": "data hash valid"
For this JPEG and tool version, the data-hash assertion provides the hard binding between the manifest and the image. assertion.dataHash.match reports that C2PA Tool successfully checked that binding.
Inspect the signature and credential
Under manifests, open the object whose label matches active_manifest, then locate signature_info.
The expected output includes:
        "signature_info": {
  "alg": "Es256",
  "issuer": "C2PA Test Signing Cert",
  "common_name": "C2PA Signer"
Under validation_results.activeManifest.success, find claimSignature.validated to confirm that the claim signature verifies.
Under validation_results.activeManifest.failure, the expected output includes:
  "code": "signingCredential.untrusted",
  "explanation": "signing certificate untrusted"
Keep the following checks separate:
  • claimSignature.validated indicates that the cryptographic signature on the claim is verified.
  • assertion.dataHash.match reports that C2PA Tool successfully checked the hard binding to the image.
  • signingCredential.untrusted indicates that the validator trust policy doesn’t accept the certificate.
A verifying signature doesn’t, on its own, establish who controls the corresponding private key.
Interpret the result
For this fixture, C2PA Tool also prints:
        "validation_state": "Valid"
Valid refers to the structural and cryptographic integrity of the C2PA manifest store. C2PA Tool can read its structure and successfully check the claim signature, referenced assertion hashes, and binding to the image.
The result describes the integrity of the provenance record and its connection to this image. It doesn’t describe the truth of the image or the recorded assertions.
Read this summary together with the individual status codes. Here, signingCredential.untrusted means that the signing certificate isn’t accepted by the configured trust policy of the tool. This is despite the integrity checks succeeding.
The tool distinguishes Valid from Trusted, which additionally requires acceptance of the signing credential under that policy.
You might also find signingCredential.ocsp.skipped under validation_results.activeManifest.informational. This means that online certificate-status fetching through the Online Certificate Status Protocol (OCSP) was skipped.
The Valid result doesn’t establish that an online revocation check succeeded. Read the result alongside the individual status codes.
Locate the C2PA structures inside the JPEG with ExifTool
The JSON report is a readable interpretation of the embedded data, not its storage format. In this JPEG, the C2PA manifest store is carried in application metadata segments called APP11 segments. A large store can span several segments. Within that store, JPEG Universal Metadata Box Format (JUMBF) organises the data into nested, labelled containers called boxes. Each manifest contains an assertion store, a claim, and a claim signature. For more information, see the C2PA JPEG storage specification .
ExifTool is a command-line utility for reading and writing file metadata. Use its read-only inspection commands to connect the fields in report.json with the structures stored in image-signed.jpg. For installation instructions, see the ExifTool install guide .
Start by listing the JUMBF labels:
-a includes repeated labels, -G3 shows their document hierarchy, and -s prints tag names.
Look for the following labels:
LabelWhat to identify
c2paThe manifest store
urn:c2pa:…The manifest label matching active_manifest in report.json
c2pa.assertionsThe assertion store, containing c2pa.actions.v2 and the c2pa.hash.data assertion that provides the hard binding to this JPEG
c2pa.claim.v2The claim that references the assertions and signature
c2pa.signatureThe claim-signature container
Trace claim connection to assertions and the hard binding
ExifTool verbose listing lets you trace how the following components connect within the nested JUMBF boxes of the image:
  • Recorded actions
  • Hard-binding parameters
  • Claim references
This view exposes the stored metadata behind the fields in the C2PA Tool report.
You can save the metadata to metadata.txt and explore it in a text editor:
exiftool -v2 image-signed.jpg > metadata.txt
The following entries help connect the stored metadata with the C2PA Tool report:
  • JPEG APP11 contains the JUMBF structure whose outer label is c2pa, identifying the embedded manifest store.
  • Under c2pa.actions.v2, the decoded c2pa.created action and digitalSourceType correspond to the declaration in manifest.json and the action shown in report.json.
  • Under c2pa.hash.data, Alg = sha256 identifies the hard-binding hash algorithm. ExclusionsStart and ExclusionsLength describe the byte range omitted from hashing. The stored hash appears as binary data without its value expanded.
  • Under c2pa.claim.v2, assertion references point into c2pa.assertions. The signature reference ends in c2pa.signature, the label of the claim-signature container.
The claim and action values are stored in CBOR, a compact binary encoding that ExifTool decodes for this listing. This view reveals the stored structures and their connections. It doesn’t verify the C2PA signature or content binding. The image remains unchanged.
You’ve inspected the recorded provenance, as well as distinguished signature and content-binding results from signer trust. You’ve also traced report fields to the structures inside the JPEG.
Keep image-signed.jpg unchanged, along with report.json and metadata.txt.
Next, you’ll use an external validator to examine the same signed image. You’ll interpret the results of the validator under its trust policy.
