Create a signed copy of the sample image
Now that you’ve downloaded a sample image, you’ll add Content Credentials to the image. You’ll save the signed image as a separate file, preserving the unsigned original.
Create the manifest definition
A manifest definition tells the Coalition for Content Provenance and Authenticity (C2PA) Tool which information to include in the manifest. An assertion is a structured statement about an asset. Assertions can describe creation and editing actions, identify source assets used as ingredients, or record metadata.
For the standard assertion types and their definitions, see the C2PA standard assertion summary . This example uses an actions assertion to declare how the image was created.
The claim generator is the software that assembles the claim and its references to assertions for signing. C2PA Tool performs that work using the example identity that you’ll provide.
In your text editor, create a file named manifest.json in your c2pa-demo working directory with the following contents:
  "claim_generator_info": [
      "name": "Arm Learning Path C2PA Example",
      "version": "1.0.0",
      "com.arm.learning_path.tool": {
        "name": "c2patool",
        "version": "0.27.21"
  "assertions": [
      "label": "c2pa.actions.v2",
      "data": {
        "actions": [
            "action": "c2pa.created",
            "digitalSourceType": "http://cv.iptc.org/newscodes/digitalsourcetype/digitalCapture"
On Windows, enable File name extensions in File Explorer. Confirm that the filename is manifest.json, rather than manifest.json.txt.
The manifest definition identifies the signing workflow and records the declared origin of the image:
  • claim_generator_info names your signing workflow Arm Learning Path C2PA Example, version 1.0.0. This version identifies the Learning Path workflow. It’s separate from the installed C2PA Tool version.
  • com.arm.learning_path.tool records the name and version of the tool. Set version to the value reported by c2patool --version. The com.arm prefix identifies this as a custom field, following the C2PA rules for extending claim-generator information .
  • assertions contains a c2pa.actions.v2 assertion. Its data.actions array records a c2pa.created action, with digitalSourceType declaring digital capture as the origin of the image.
    You’ll supply this declaration to complete the Learning Path. C2PA Tool doesn’t verify how the image was created.
    Signing makes changes to the declaration detectable. Signing doesn’t establish that it’s true.
    An action can also include softwareAgent to identify the software or hardware that performed it. You omit that field because the original capture agent of the sample is unknown. C2PA Tool generates the claim but doesn’t capture the image.
C2PA Tool generates the claim, content-binding data, and signature when it builds the signed manifest. You don’t write those cryptographic structures manually.
C2PA Tool also offers a command-line shortcut: with an empty assertions array, --create digitalCapture adds the creation action. If you omit claim_generator_info, the tool supplies its own name and version instead of this example label. Keep the explicit claim-generator information to retain the Learning Path label. You’ve already defined the creation action in manifest.json, so omit --create when signing the image.
Understand the development credentials
The example development credentials use the private key and signing certificate that are built into C2PA Tool. These credentials let you practice signing, but don’t establish a production identity or trust by public validators. Don’t use them to sign production content. Use the development credentials to complete the Learning Path for consistent validation results.
For production, C2PA Tool supports an external signer. The signer supplies the certificate chain and uses the corresponding private key without exposing it to the tool. When you have such a signer, the command takes this form:
c2patool image.jpg --manifest manifest.json --signer-path /path/to/production-signer --output image-production-signed.jpg
This is an illustrative alternative. Don’t run the command.
/path/to/production-signer is a placeholder for an executable implementing the C2PA Tool signer protocol . It’s not a certificate file.
The signer supplies its certificate chain and signing algorithm, and it manages access to the private key. Don’t copy production private keys into the manifest definition.
For production conformance requirements, see C2PA Conformance Program .
Sign the image
Sign the image in the c2pa-demo directory. Ensure that a file with the same name as the output doesn’t already exist. If it does, move or rename the existing file before you continue:
--manifest manifest.json supplies your definition. --output image-signed.jpg writes the signed image to a separate file, leaving image.jpg unchanged.
The command exits with status 0 when signing succeeds.
The output includes the following development warning:
        Note: Using default private key and signing certificate. This is only valid for development.
A permanent key and cert should be provided in the manifest definition or in the environment variables.
The command also prints the generated manifest report. Its generated identifiers differ between runs. You’ll inspect the report later.
Confirm that the signed file contains a manifest
Inspect the signed image to check that a manifest is present:
c2patool image-signed.jpg --info
The expected output includes:
        Validation issues:
   signingCredential.untrusted
One manifest
One manifest confirms that the output contains a C2PA manifest. signingCredential.untrusted is the expected trust result for this development certificate. It doesn’t mean that signing failed.
The byte counts and percentages printed by this command can vary.
You’ve defined the provenance information, signed the image, and confirmed that the output contains a manifest.
Keep the following three files to complete the rest of the Learning Path:
FilePurpose
manifest.jsonYour claim-generator information and creation assertion
image.jpgThe unchanged unsigned source image
image-signed.jpgThe signed image containing the C2PA manifest
Next, you’ll inspect the generated manifest and confirm that C2PA Tool reports a valid signature and content binding.
