Vector tables have a relatively small and fixed number of entries. A real system will likely require many different interrupts, triggered by different sources. An additional piece of hardware is needed to manage these interrupts. The Arm Generic Interrupt Controller, GIC does exactly this.
Set up Generic Interrupt Controller (GIC)
Create gic.s with the following code to initialize the GICv3 implemented in the FVP, and define the timer as a source of interrupts.
For detail on this code, see the GICv3 and GICv4 Software Overview .
gic.s
	.section GIC,"ax"
	.global gicInit
	.type gicInit, "function"
gicInit:
	// Configure Distributor
	MOV      x0, #0x2f000000	// GIC Distributor, GICD
	// Set ARE bits and group enables in the Distributor
	ADD      x1, x0, #0x0	// GICD_CTLROffset
	MOV      x2,     #0x20  // GICD_CTLR.ARE_NS
	ORR      x2, x2, #0x10  // GICD_CTLR.ARE_S
	STR      w2, [x1]
	ORR      x2, x2, #0x01	// GICD_CTLR.EnableG0
	ORR      x2, x2, #0x04	// GICD_CTLR.EnableG1S
	ORR      x2, x2, #0x02	// GICD_CTLR.EnableG1NS
	STR      w2, [x1]
	DSB      SY
	// Configure Redistributor
	// Clearing ProcessorSleep signals core is awake
	MOV      x0, #0x2f100000	// GIC Redistributor, RD_base
	MOV      x1, #0x14		// GICR_WAKERoffset
	ADD      x1, x1, x0
	STR      wzr, [x1]
	DSB      SY
waiting:   // Wait for ChildrenAsleep to read 0
	LDR      w0, [x1]
	AND      w0, w0, #0x6
	CBNZ     w0, waiting
	// Configure CPU interface
	// Set the SRE bits for each EL to enable
	// access to the interrupt controller registers
	MOV      x0, #0x8		// ICC_SRE_ELn.Enable
	ORR      x0, x0, #0x1	// ICC_SRE_ELn.SRE
	MSR      ICC_SRE_EL3, x0
	ISB
	MSR      ICC_SRE_EL1, x0
	MRS      x1, SCR_EL3
	ORR      x1, x1, #1		// Set NS bit, to access Non-secure registers
	MSR      SCR_EL3, x1
	ISB
	MSR      ICC_SRE_EL2, x0
	ISB
	MSR      ICC_SRE_EL1, x0
	MOV      w0, #0xFF
	MSR      ICC_PMR_EL1, x0 // Set PMR to lowest priority
	MOV      w0, #3
	MSR      ICC_IGRPEN1_EL3, x0
	MSR      ICC_IGRPEN0_EL1, x0
	// Secure Physical Timer source defined
	MOV      x0, #0x2f110000	// GIC Redistributor, SGI_base
	ADD      x1, x0, #0x80		// GICR_IGROUPRoffset
	STR      wzr, [x1]          // Mark INTIDs 0..31 as Secure
	ADD      x1, x0, #0xD00		// GICR_IGRPMODRoffset
	STR      wzr, [x1]          // Mark INTIDs 0..31 as Secure Group 0
	ADD      x1, x0, #0x100		// GICR_ISENABLERoffset
	MOV      w2, #(1 << 29)     // Enable INTID 29
	STR      w2, [x1]           // Enable interrupt source
	RET
Other functions
Define these functions in your gic.s source:
gic.s
	.global readIAR0
	.type readIAR0, "function"
readIAR0:
	MRS       x0, ICC_IAR0_EL1  // Read ICC_IAR0_EL1 into x0
	RET
	  .global writeEOIR0
	  .type writeEOIR0, "function"
writeEOIR0:
	MSR        ICC_EOIR0_EL1, x0 // Write x0 to ICC_EOIR0_EL1
	RET
These functions will be used in your fiqHandler() implementation (written in C).
Generic Timer
A Generic Timer is present in all Armv8-A processors.
Create timer.s defining the following functions:
timer.s
	.section  AArch64_GenericTimer,"ax"
	.global setTimerPeriod
	.type setTimerPeriod, "function"
setTimerPeriod:
	MSR     CNTPS_TVAL_EL1, x0
	ISB
	RET
	.global enableTimer
	.type enableTimer, "function"
enableTimer:
	MOV    x0, #0x1            // Set Enable bit, and clear Mask bit
	MSR    CNTPS_CTL_EL1, x0
	ISB
	RET
	.global disableTimer
	.type disableTimer, "function"
disableTimer:
	MSR    CNTPS_CTL_EL1, xzr // Clear the enable bit
	ISB
	RET
Enable GIC and Timer
Modify hello.c to enable the GIC and timer, and create a simple test. You can use printf() statements to follow execution flow.
hello.c
#include <stdio.h>
#include <stdint.h>
#include "uart.h"
__asm(".global __use_no_semihosting\n\t");
// defined in gic.s
extern void		gicInit(void);
extern uint32_t readIAR0(void);
extern void		writeEOIR0(uint32_t);
// defined in timer.s
extern void 	setTimerPeriod(uint32_t);
extern void 	enableTimer(void);
extern void 	disableTimer(void);
volatile uint32_t flag;
int main (void) {
  uartInit((void*)(0x1C090000));
  printf("Hello World!\n");
  flag = 0;
  gicInit();
  setTimerPeriod(0x10000);
  enableTimer();
  printf("Waiting for interrupt...\n");
  while(flag==0){};
  printf("Returned from interrupt!\n");
  return 0;
Create fiqHandler()
Create the fiqHandler() function in hello.c. It reads the INTID register when triggered, disables the timer, and sets flag.
hello.c
void fiqHandler(void) {
  uint32_t intid;
  intid = readIAR0(); // Read the interrupt id
  printf("Interrupt %d occurred\n", intid);
  if (intid == 29) {
    disableTimer();
	flag = 1;
  else
	printf("Another interrupt occurred??\n");
  writeEOIR0(intid); // Clear interrupt
  return;
Build and run the complete project
You are now ready to test the application. Build the project with:
armclang -c -g --target=aarch64-arm-none-eabi startup_el3.s
armclang -c -g --target=aarch64-arm-none-eabi uart.c
armclang -c -g --target=aarch64-arm-none-eabi vectors.s
armclang -c -g --target=aarch64-arm-none-eabi gic.s
armclang -c -g --target=aarch64-arm-none-eabi timer.s
armclang -c -g --target=aarch64-arm-none-eabi hello.c
armlink --scatter=scatter.txt --entry=el3_entry startup_el3.o uart.o vectors.o gic.o timer.o hello.o -o hello.axf
To enable the timer in the FVP, add the -C bp.refcounter.non_arch_start_at_default=1 option to the command line.
FVP_Base_AEMvA -C bp.refcounter.non_arch_start_at_default=1 -a hello.axf
Observe the application reporting that the exception occurred.
        Hello World!
Interrupt 29 occurred
In _sys_exit. Use Ctrl+C to quit.
