Explore related resources
Give feedback
AI-assisted
Close
What is an AWS IoT Greengrass deployment?
A deployment is a defined set of components and their configurations managed by AWS IoT Greengrass. You’ll use it to apply or update components on your device.
Where do I create a Greengrass deployment in the AWS console?
Go to IoT Core, then navigate to Manage > Greengrass devices > Deployments and select Create.
Can I change which components are in a deployment after I create it?
Yes. You can modify a deployment to change configurations, add components, or remove components.
Which virtual device should I start in Arm Virtual Hardware?
Start a Raspberry Pi 4 virtual device to align with the steps in this Learning Path.
Will I be charged while following this Learning Path?
A new AVH account is automatically enrolled in a free 30-day trial. AWS requires a credit card, but the steps use free tier only and can be completed without incurring charges.
Return to Embedded and Microcontrollers
