Explore related resources
Give feedback
AI-assisted
Close
What device type should I select in Arm Virtual Hardware?
Choose Raspberry Pi 4 when creating the device in Arm Virtual Hardware.
Which firmware option and file do I use when creating the AVH device?
Use the Upload your own firmware option and select the balenaos_rpi4b.zip file.
How do I access Balena Hub from the Balena Cloud dashboard?
Click the Balena Hub button in the top right corner of the Balena Cloud dashboard.
Which example application should I deploy from Balena Hub?
Open Apps on Balena Hub and search for balena-app. This example provides a Grafana dashboard.
What result should I expect after deploying the Grafana example?
The Grafana dashboard displays the state of your BalenaOS device, confirming that the application deployed to the virtual Raspberry Pi 4.
Return to Embedded and Microcontrollers
