Embedded programming with Arduino on the Raspberry Pi Pico
About Embedded Programming
Application Programming
Embedded Programming on Arm
Build a smart device prototype
Program your smart device prototype
Learn about interrupts
Add the interrupt code
Refactor the application
Select an RP2040-based board from the installed package and choose the USB/serial port associated with the Raspberry Pi Pico. If the upload fails, recheck both the board and port selections.
Connect the PIR output to a digital input pin and the buzzer to a digital output pin with a common ground. Make sure the pin numbers in your wiring match the pin definitions used in the sketch.
When motion occurs, the buzzer responds immediately without waiting for a timed loop. If you see an instant reaction when the PIR output changes, the interrupt handler is being invoked.
Verify power and common ground, confirm the selected GPIO pins match the sketch, and ensure the input is configured for the PIR signal and the output drives the buzzer. Also recheck that the correct RP2040 board and port are selected and that the upload completed successfully.
No. The example runs on bare metal using Arduino tooling on the RP2040. Any RTOS stack references are for context about typical Arm embedded architectures, not for this build.
