Understand the ExecuTorch path
You previously used LiteRT and Tensor Operator Set Architecture (TOSA) artifacts with Vela. You can also use Arm ML Inference Advisor (MLIA) if you’re working with an ExecuTorch flow.
A .pte file is a portable ExecuTorch executable: the packaged artifact that ExecuTorch can load and run.
You’ll compare two packaged .pte artifacts with Corstone backends.
Compare prebuilt ExecuTorch artifacts
The model artifacts repository includes prebuilt Ethos-U .pte files:
        pte/toy_conditional_select_int8_ethos_u55_256.pte
pte/toy_conditional_select_int8_ethos_u85_256.pte
These are synthetic learning artifacts rather than benchmark models. The artifacts use a small convolution plus a conditional selection pattern to make target-dependent delegation easier to see. A model can be packaged for different Ethos-U targets and show different delegation and runtime-counter behavior.
For supported .pte workloads, MLIA performance analysis uses a Corstone backend. In this context, Corstone refers to an Arm reference subsystem platform. The backend uses a Fixed Virtual Platform (FVP).
An FVP is a software model of a hardware platform. You can use an FVP to run a packaged artifact in a target-like environment and collect performance counters without needing a physical board on your desk.
For .pte artifacts, MLIA currently supports only performance analysis. The artifact has already been packaged for an ExecuTorch deployment path. Corstone is used to run the packaged program on an FVP and collect NPU performance counters for the whole model run.
Corstone doesn’t provide per-layer estimates or operator breakdowns. Perform a Vela-backed analysis similar to earlier when you need layer-level performance estimates or compatibility checks.
Run the Ethos-U55 artifact with the Corstone-300 backend:
mlia check pte/toy_conditional_select_int8_ethos_u55_256.pte \
  --target-profile ethos-u55-256 \
  --performance \
  --backend corstone-300
Running the check installs any required Corstone backends that weren’t previously installed.
Note
Corstone backend installation requires accepting a license. You’ll be prompted in the terminal to agree.
Run the Ethos-U85 artifact with the Corstone-320 backend:
mlia check pte/toy_conditional_select_int8_ethos_u85_256.pte \
  --target-profile ethos-u85-256 \
  --performance \
  --backend corstone-320
The reports show Corstone running each .pte artifact and collecting NPU performance counters for the whole model run. Read the Corstone report as runtime counter evidence:
FieldWhat it tells you
NPU active cyclesCycles where the NPU was doing work.
NPU idle cyclesCycles where the NPU was present but not active. A very small value means this run kept the NPU busy after work was issued.
NPU total cyclesActive plus idle cycles for the NPU portion of the run.
NPU AXI0 RD/WR data beatMemory traffic on the AXI0 port, configured as SRAM for this target profile.
NPU AXI1 RD/WR data beatMemory traffic on the AXI1 port, configured as DRAM for this target profile.
Use the reports to compare the NPU counters for each packaged artifact:
ArtifactTarget profileBackendNPU total cycles
toy_conditional_select_int8_ethos_u55_256.pteethos-u55-256corstone-300273,088
toy_conditional_select_int8_ethos_u85_256.pteethos-u85-256corstone-32019,056
The comparison uses ethos-u55-256 and ethos-u85-256, so both target profiles use 256 MACs per cycle. However, Ethos-U85 is a newer and higher performance NPU than Ethos-U55. The target information in the reports also shows other platform differences, such as accelerator clock and memory configuration.
The Ethos-U55 report shows 271,725 NPU active cycles and 1,363 NPU idle cycles. The Ethos-U85 report shows 18,183 NPU active cycles and 873 NPU idle cycles, for 19,056 total NPU cycles. This difference reflects the combined effect of improvements in Ethos-U85 over Ethos-U55.
Use the Corstone counters to compare packaged artifacts under the same target profile and backend. If part of the graph runs outside the NPU delegate, the CPU-side cost isn’t fully represented by the NPU cycle table.
Use Model Explorer for graph structure
You’ve used MLIA with LiteRT, TOSA, and ExecuTorch .pte artifacts. MLIA answers target-aware questions about compatibility, estimated performance, runtime counters, and advice. To see how these artifacts can be visualized as graphs in Model Explorer, continue with the Explore model artifacts with Model Explorer Learning Path. You’ll use many of the same files from the model artifacts repository.
Model Explorer can open some formats directly, while other formats use adapters. Use Model Explorer alongside MLIA when you want to connect target advice with the graph structure that produced it.
In the earlier example, Ethos-U85 is expected to perform better due to its platform differences. The model also delegates differently for Ethos-U85 compared to Ethos-U55.
The model pattern is:
        convolution / activation
conditional select
convolution / activation / convolution
On Ethos-U55, the conditional select part isn’t kept inside the Ethos-U delegate path. The partitioning is as follows:
        EthosUBackend region
aten::gt / aten::where outside delegate
On Ethos-U85, this backend flow handles the model pattern more cleanly, so the packaged artifact has one EthosUBackend region. This provides a further performance benefit because it reduces fragmentation between CPU and NPU. Use Model Explorer with Arm adapters to visualize how models delegate to different backends.
Note
An ExecuTorch .pte file can contain work outside an accelerator delegate. However, there’s no guarantee that every non-delegated operator can run on the CPU runtime that you deploy. CPU execution depends on the kernel libraries linked into that runtime and the operators, dtypes, layouts, and shapes that they support.
Cortex-M bare-metal runtimes are usually built with a smaller, more selective kernel set than Cortex-A runtimes. The difference in kernel set is because Cortex-M systems have tighter memory and storage constraints. In both cases, CPU fallback support depends on which kernels are included in the runtime build.
What you’ve accomplished
You’ve learned how .tflite, .tosa, and .pte fit into MLIA workflows. You’ve also seen why .pte is useful for ExecuTorch artifact analysis, where TOSA can fit as an intermediate handoff, and why Model Explorer remains useful for graph structure.
You can extend this CLI workflow to evaluate other models for whether they’re suitable for a target. If you want to call MLIA from automation or another tool, see (Optional) Use the MLIA Python API .
To learn how to use the Visual Studio Code extension for MLIA, see (Optional) Use the MLIA and Model Explorer Visual Studio Code extension .
