Analyze Arm Ethos-U models with Arm ML Inference Advisor
Understand where MLIA fits in model preparation
Install MLIA and discover capabilities
Analyze LiteRT artifacts with MLIA and Vela
Analyze TOSA IR artifacts with MLIA and Vela
Analyze ExecuTorch artifacts with MLIA and Corstone
(Optional) Use the MLIA Python API
(Optional) Use the MLIA and Model Explorer VS Code extension
What TOSA is
Tensor Operator Set Architecture (TOSA) is an intermediate representation (IR) for machine learning graphs. It’s a stable set of tensor operators that can sit between a model framework and a target backend. The TOSA specification defines the operator set and semantics.
Instead of asking every backend to understand every framework operator directly, a conversion flow can lower supported parts of a model into TOSA. Backend tools can then analyze or compile that TOSA graph for a target.
TOSA can appear in more than one kind of ML workflow. Some compiler flows for LiteRT models can use TOSA as an IR. Other LiteRT flows hand a .tflite file directly to a backend tool such as Vela. In the ExecuTorch Arm Ethos-U flow, supported PyTorch graph regions are lowered to TOSA before Vela compiles them for Ethos-U.
Compare FP32 and INT8 TOSA artifacts
The model artifacts repository includes floating-point and quantized TOSA variants:
tosa/mv2_fp32.tosa
tosa/mv2_int8.tosa
Start by running Arm ML Inference Advisor (MLIA) on the FP32 TOSA model:
mlia check tosa/mv2_fp32.tosa \
--target-profile ethos-u85-256 \
--compatibility \
--backend vela \
--json
The result is similar to the FP32 LiteRT check. The model can be expressed as an artifact, but it’s not in the supported quantized integer form required for Ethos-U acceleration with this target profile. The important distinction is that TOSA describes an intermediate graph form rather than a complete runtime deployment.
Run the same MLIA compatibility check on the quantized INT8 TOSA model:
mlia check tosa/mv2_int8.tosa \
--compatibility \
--backend vela \
--json
The INT8 TOSA report shows status as ok and accelerator_operator_percentage as 100.0. The model format is now TOSA, but the target profile and Vela backend configuration are the same as the LiteRT run.
The difference from the FP32 TOSA artifact is that the INT8 artifact has the quantized representation required for Ethos-U acceleration. The operator support checks pass, and MLIA expects the operator work to map to the NPU path.
You can also run a performance check using the INT8 .tosa model:
--performance \
--backend vela \
--json
The report is similar to the INT8 LiteRT performance result. The model maps to the NPU path. MLIA reports NPU-scoped estimated metrics, and the advice points you toward operators that dominate estimated cycles or have low utilization.
Whether TOSA with MLIA is useful depends on your workflow. Many developers will likely use ExecuTorch or LiteRT artifacts directly.
You’ve seen how the same MLIA CLI pattern applies to TOSA, and how TOSA bridges model formats and backend compilation.
Next, you’ll learn how packaged ExecuTorch .pte artifacts fit into the same MLIA workflow.
